Modifying data in the internal SX EEPROM
I need to be able to occasionally modify a couple of·constants in the internal SX EEPROM without reloading software. The Basic Stamp has a WRITE command for this, and I have used it several times to modify operating data.
Is there a way to do this on the SX chip??
regards peter
If you want a small SX48 based module with external EEPROM you might be interested in a kit I made up for the SX48 a while back:
http://forums.parallax.com/forums/default.aspx?f=7&m=194701
It will fit easily on a breadboard and comes with an external EEPROM chip. They are handy little modules.
Best Regards,
Robert
The actual controller on the Stamp uses "flash" memory just like the SX -- and it can not be modified -- it's a different process altogether from writing values to EEPROMs. Part of what makes the Stamp so dang handy and elegantly cool is all the "conveniences" that you may take for granted -- read/writeable EEPROM, high-level commands, on-board voltage regulation, PC serial connection, etc.
Basically if you take an SX, add a regulator, EEPROM, crystal, RS-232 level shifter, and 2k of what must be *highly* efficient assembly code that reads additional commands off the EEPROM and runs them -- you've just invented a Basic Stamp
If you need non-volatile memory on your SX you have a few ways to go depending on your needs:
- use I2C commands to access a traditional EEPROM if you need to read and/or write many values that don't change very often, and speed is not a huge issue. Dirt cheap.
- use I2C or serial on a chip like the DS130x real time clocks -- they contain about 40 non-volatile RAM registers. The advantage here is speed of reading/writing to the registers and the bonus of a having a real time clock source. The disadvantage here is the need for a backup super-cap or battery for the device.
- FRAM. Operates kind of like a traditional EEPROM but with much greater speed and without the write/read/rewrite life-expectancy problems of EEPROMs. Not as cheap, though, I don't think.
I will look into adding an external EEPROM on my next product. Unfortunately the current design is too far along so my customer will be disappointed (that's what he gets for asking for this feature so late in the game).
