H11AA1 Opto-Coupler Biasing
I'm planning to use an H11AA1 Opto-Coupler to sense 120 VAC and want to make sure I have the input diodes properly biased.
The H11AA1 diode inputs will be connected across the 120 VAC line (see attachment).
The datasheet for the H11AA1 indicates a maximum continuous current for the diodes of 60 ma.
I'll use half that as the target current, 30 ma.
So the size of the two resistors, one on each of the two diode inputs, would be 120 VAC / 30 ma = 120 VAC / 0.030 A = 4 K ohm.
Resistor wattage would be W = VI = 120 VAC X 0.030 A = 3.6 W
Am I calculating these resistors correctly? Thanks
Why do you figure that you need 30ma ?
Connect a pull-up to the output; you'll get a short, high-going pulse every 8.33 milliseconds (this happens near the zero-cross point when the voltage input falls below the LED threshold and the transistor stops conducting).
Post Edited (JonnyMac) : 12/8/2007 1:37:28 AM GMT
·· I would like to use it to read·load changes·like a ·AD convertor and send the value to the SX Comp as a load feedback for my Inverter project. It will isolate my circuit and provide load change feedback to the SX48 to adjust my PWM....
When my inverter is first turned on I can read both diode values and the have the program pick the better input of the two.. Then I can just look at every half cycle and look for the load changes·so·I can adjust the PWM to the load on the inverter leads..
I have it like in the first·Sche and I saw the opto connected·like the second Sch. I just don't know how they did it but it does work with the opto conected like that.. I am going to look at the output of the opto that is going into the Chip.. I will look at it and see but if I can't figure it out I will use the transformer and the AD chip....Thanks again
