Fun with pointers — Parallax Forums
Fun with pointers
RedNifreRedNifre Posts: 84
edited 2007-12-10 00:21 in Propeller 1
Hello!
I have several arrays and one pointer to the currently active array. Lets say I want to change the fourth LONG of the currently active array. How to do that?
  [noparse][[/noparse]...]
  arrayPointer := @array3
  ??arrayPointer??.LONG[noparse][[/noparse] 4 ] := 99
DAT
  array1 long blablabla
  array2 long blablabla
  array3 long blablabla
  array4 long blablabla
Hydra in a LEGO NES:
http://forums.parallax.com/showthread.php?p=654788
    edited 2007-12-09 20:15
    I like to use this
    'Build Render Table
        repeat index from 0 to 189 * 4 step 4
          byte [noparse][[/noparse]@render_tab] [noparse][[/noparse]index] := 0           'set background color
          byte [noparse][[/noparse]@render_tab] [noparse][[/noparse]index + 1] := $20       'set sprite 0 x pos
          byte [noparse][[/noparse]@render_tab] [noparse][[/noparse]index + 2] := $40       'set sprite 1 x pos
          byte [noparse][[/noparse]@render_tab] [noparse][[/noparse]index + 3] := $00       'unused at present
    That's an array of longs, but I need to modify bytes. @render_tab is an array of bytes, organized into longs. index is the address pointer. It's some code I'm working on right now.
    In your case, since you are working with longs, you can just take the number of the long you want to modify, multiply it by 4, then do:
    long [noparse][[/noparse]@your_array] [noparse][[/noparse]index] := value of long
    , where index = number_of_long * 4
  • CardboardGuruCardboardGuru Posts: 443
    Try LONG[noparse][[/noparse] arrayPointer][noparse][[/noparse] 4]:=99
    Help to build the Propeller wiki - propeller.wikispaces.com
    Play Defender - Propeller version of the classic game
    Prop Room Robotics - my web store for Roomba spare parts in the UK
  • RedNifreRedNifre Posts: 84
    edited 2007-12-09 21:22
    Ah, thanks alot!
  • AndreLAndreL Posts: 1,004
    There are a lot of ways to manipulate memory with SPIN both the reference manual and the HYDRA book have examples. The HYDRA book has pretty long section on this since there are a lot of features that you can do with pointers and casting that I wanted to cover, so make sure to check that out if you have the book.
    Andre'
