Tiny H Bridge Drivers
I have a project where i will need to drive a tiny cell phone vibrator motor both forward and reverse. The motor is connected to a sprocket using a worm gear. Any suggestions? The kickback pulsing one of these is 25V and the motor uses about 60 mA.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (Phil Pilgrim (PhiPi)) : 12/5/2007 7:15:12 AM GMT
I've used the those Zetex parts before and they are great. They also offer some MOSFET versions to choose from.
http://www.zetex.com/3.0/3-3-2b.asp?rid=42
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 12/6/2007 8:49:05 PM GMT
and its also good to 46 volts...
Post Edited (ChrisP) : 12/9/2007 1:37:47 AM GMT
Try http://www.solarbotics.net/library/circuits/driver_tilden.html
It seems good to 60 volts. Discrete components may actually be more durible as they have more surface area to dump heat -- certainly cheaper than ICs. And, I wonder if you really need MOSfets.
There are refinements to this that will optimize power. And, you can alternatively use 4 transistors and an IC to drive the transistors. I just can't seem to Google the right reference for the optimized designs.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
