SX inputs pulled below ground....?
I just assembled my spiffy new batch of miniboards, well the first one anyway. Looking at the board layout I realized that I made a horrible mistake. The optoisolator and resonator are both grounded to the incoming ground to the board while the vreg is grounded through a 1n4004 diode.. This would put the opto and resonator ground at -.6V...... Can I get away with this or is it time to cut traces and manualy move the ground lines to match the SX?
All other traces are fine, no other mixed grounds. Just the resonator and opto....
Silly question but I really dont know how it will effect the resonator or input lines...
I asked because sometimes there is knowledge that isnt in data sheets, all things look good on paper, reality has a way of changing paper specs though as I'm sure you already know.
