Scrolling 7 seg. Display — Parallax Forums
Brian_BBrian_B Posts: 844
edited 2007-12-09 03:45 in Propeller 1
Hi,
·I wrote this code to scroll a 7 seg led display. Pin 15 is vss and 16 through 23 lights the segments. It seems to work ok , but there is a pause in the reset loop.·Any clue why it's pausing for more than the waitcnt ?
Thank's Brian
http://tech.groups.yahoo.com/group/lunarX/
·"Imagination is more important than knowledge..." ·· Albert Einstein
http://www.diycalculator.com/subroutines.shtml· My favorite website ( Bet you can't guess why)
Post Edited (Brian Beckius) : 12/7/2007 7:54:24 PM GMT
  • deSilvadeSilva Posts: 2,967
    edited 2007-12-07 23:41
    I think this
    cmp   23,outa                wz
    shpuld read
    cmp   test1,outa                wz
    Note that it is not a good idea to connect the common cathode to a I/O pin. It will have to suck the curent of all segments wihct can go up to 70 mA... It will not of course, rather it will look dim... smile.gif
  • Brian_BBrian_B Posts: 844
    edited 2007-12-07 23:55
    deSilva,
    I started out with the test1 deal , It will only makes the loop once. If I use the version I posted , theres a delay in every loop (not the waitcnt delay).
    Thank's Brian
    edited 2007-12-07 23:57
    The version you posted makes no sense!
    And yes, of course it will only work again after bit 23 has been shifted out of the 32 bit register again.
    Best you reconsiderthe algorithm you plan to use again.
    Post Edited (deSilva) : 12/8/2007 12:02:38 AM GMT
    edited 2007-12-07 23:58
    Thank's
    Thank's Brian
    edited 2007-12-08 00:02
    What I wanted to say is that there is no "bug" to catch...
    You have to rewrite it.
    edited 2007-12-08 23:08
    Ok,
    ·Does this look any better ?
    Thank's Brian
    edited 2007-12-09 03:08
    The question is: Does it work?
    As long as you are shining just one segment this is fine, but notice the load to I/O 15 I pointed to in my first posting.
    And I noticed you are also enabling I/O 14 for output - for any reason?
    Yes it does work, well at least to the point that I can move forward. Thank you for not just posting “the code”, sometimes I just need a little kick in the butt to rethink stuff.
    Thank's Brian
