FT232 alternative?
Has anyone tried to use an alternative uart? the ssoc footprint will be difficult to prototype out on the CNC routers due to the pitch size. Just wondering if there is something that would do the same job in a dip or soic 100mil pitch.
hmm..
I'll keep it in mind though if I run out of options. At least I can build the serial aspect of it for now, but I really want to get the usb implimented at some point.
The FTDI UM232R 24 pin DIP breakout board is on this page www.ftdichip.com/Products/EvaluationKits/UM232R.htm.
Or, design a little breakout board yourself and have a panel of them made. You might even be able to sell some.
At www.sparkfun.com they have breakout boards with the FTDI chip, USB connector, and misc. other parts needed for both the FT-232RL (SKU#: BOB-00718, $14.95 USD) and FT245RL (SKU#: BOB-07841, $17.95 USD). But at first glance these don't look like the breakout is on 0.1" centers. But with a little ingenuity, some pins and break-apart sockets, I'm sure you could get these little sparkfun board to mount like daughter-boards.
Good Luck,
David
Regards
Gerry
There is a picture (4th page of the thread about 3/4 way down) of the setup I use here: http://forums.parallax.com/showthread.php?p=679308
Overall, I'm disturbed about the cost of these USB/Serial parts from the likes of FTDI. A PropPlug is $30. Even the Sparkfun breakout board is $15 and SparkFun is not known as a gouger. I would've thought someone would come up with a Prop app that deals with the USB port directly using some sort of Open USB virtual COM port driver or something. Heck, PIC parts that cost a few bucks in small quantity should at least be able to handle USB at low rates. Obviously I'm missing something here. Royaties to the USB-Cartel? Heck I was out in a shopping mall today and saw a 128MB MP3 player with a USB interface (no display) for $25 USD, and I'm sure there are cheaper examples out there. Why should we be paying so much for a seemingly simple thing? Economies of scale, licensing/Lawyers/Patents, what? Again, a PropPlug is $30, a Prop Proto-Board is $20, even in volume and PCB area compared between the two, there is something amiss here.
End of Rant...
David
Thanks for the tips everyone, I was looking for more of any else besides FTDI that is more prototype friendly. Daughter boards work and all, but for me I'd rather have a more complete final solution. I guess I can look at a breakout board, but its more wiring and more ways for something to fail via breakout wiring.
I'll have to plug a way a bit more.
If I come up with something I'll post back to see what your input is.
FT232RL and FT232RQ chips are just $5 as one offs, $4 at 100 off so any excessive cost cannot be laid entirely at FTDI's door. I'm at a loss to understand why a PropPlug is so much more expensive than a ProtoBoard.
With UK supplier's 60% mark-up on ProtoBoards ($32) and only 30% mark-up on the PropPlug ($40) the differential isn't as noticeable
Post Edited (hippy) : 12/7/2007 4:28:45 PM GMT
It will be a bit more difficult to solder, but at least I can route it on the machines and try to get it going.
$8.72 or so but I bet it chews gum too. (5 usb, 2 serial, i2c....)
100 pins to solder by hand....neh......
On second thought the RS-232 on the cable is probably +/- voltage. So this means in the $12 USB/RS232 cable there's even more complexity involved compared with the $29.95 prop-plug; a USB/serial bridge function back to back with a serial/RS-232 level shifter. Imaging an FT232 back to back connected to a MAX232.
Post Edited (Drone) : 12/8/2007 7:00:01 AM GMT
I missed these SparkFun SSOP-28 break-out boards (BOBs) when I was searching. Nice find.
However, my problem with BOBs in-general is plugging them into DIP sockets and/or plug-protoboards. As SparkFun states on the link you provided (full URL echoed for those that save posts using "print version" www.sparkfun.com/commerce/product_info.php?products_id=500), the breakaway pin headers shown as "related items" are often too big to fit into DIP sockets and for similar reason often "stress" plug-protoboard holes to the point where they don't like taking smaller guage wires any more. I wish we could find a reasonably priced bag of qty 50s, 100s or so individual socket-pluggable pins that can be soldered into these DIP BOBs to solve this problem. Still searching. P.S. the breakaway headers with their square pins do work well for wire-wrap on a 0.1" centered perf-board, and they can be easily obtained in longer pin lengths and small quantity for multiple wraps. But I think that's not what the original poster Kitmaster is looking for. Addressing the smaller pin issue may provide Kitmaster with a solution.
David
http://forums.parallax.com/showthread.php?p=667708
The ideal terminals for the breakout board would be the Samtec TS series (DigiKey) in the 0.018" (.46mm) diameter. Anything above 0.020" will overstress the socket. Oddly enough, SparkFun sells machined-pin terminal strips, but the diameter, at 0.025" on one end (0.030" on the other), is too large.
One thing I dislike about generic breakout boards, though, is that there are no pads for bypass caps which, by all rights, should be mounted close to the chip. By the time a chip lead gets routed around the board and down the connecting pin, there's so much inductance involved that any bypassing measures taken on the host PCB are compromised.
Anyways, here is the link: http://forums.parallax.com/showthread.php?p=675656
Harisson, Thanks for the USB driver link. I missed that one.
David
1. Qty.-1, SparkFun SSOP to DIP Adapter 28-Pin, SKU#: BOB-00500, Unit Price: $3.95 ea.
2. Qty.-1, Breakaway Pin Header 0.1" 32 position, tin plated, Samtec P/N SAM1112-32-ND, Digikey P/N TS-132-T-A, Unit Price: $3.22 ea.
www.samtec.com/technical_specifications/overview.aspx?series=TS
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=SAM1112-32-ND
This solution has no parts on the breakout board other than the FTDI chip - this is a good.
David
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
I think kittmaster (originating Poster) is looking for a USB to serial (serial at logic levels, not true RS-232 phy) solution in a DIP footprint. Nobody so-far it seems can find the likes of FTDI USB/serial in native DIP form-factor.
The MAX3232 (DIP package P/N MAX3232CPE) takes serial logic levels to/from true RS-232. This is different from what kittmaster was asking about. Even though this thread diverges at times (mea culpa) from Kittmaster's original request (as I interpret it), in the end I think we've provided a summary solution scraped from the contributions of others herein that is best as of today. If Kittmaster isn't interested in the solutions (Hello - Kittmaster?), at least the thread is here for others.
Happy Holidays...
David
Still here, yes drone you are spot on. While I understand the new parts have less components, they are very difficult to prototype and solder by hand. I have 1/64th tips to do the job, but its getting the copper cut properly.
I am still looking for a native solution, the ssop is just way to small to be done by hand so is the QFN. The BM device is the only footprint that is remotely possible to properly prototype hence way I got a few samples of it.
I understand there are breakout boads, but I don't want that, my final design shall not have any type of daughter board since it will add to possible failure into the design.
THis is for automotive application and the vibration over time.....is well.....something I want to avoid.
At this point I'm also consideringa PIC solution since I can't find a proper dip version.......but I understand why dips are not used (usb keys and such)
He's been asking for a UART. A "universal asynchronus receiver / transmitter".
Quite a vague question, leaving room for interpretation what he really meant.
A different UART for the propeller would be just a different COG.
Nick
YADRO
