Dead Prop
Finally managed to kill one of my Props [noparse]:([/noparse]
Knew it had to happen one of these days...
I was having some power supply issues when it died (dragged down the supply with too much load)...· But, I'm not really sure why that would have killed the proto board...
I'm only upset because of all this stuff I had on it, that I need to move to a new board...
As far as troubleshooting, I don't think there's much you can do if it won't "identify" from the Prop Tool, right?
It's got good 3.3 Vdd...
Paul Baker
Condolences!
Repair it? I mean if you know that it is the Prop, I'd unsolder it and put a new one in.
If you have a scope, trace the signals in and out to P30, P31 when connected to the PropTool. On power up (w/o PropTool) you should see a signal on P28/P29. Check wether BOEN is sett right.
But if a new board costs only $19.95, it's not worth fireing up the solder iron.
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
Beau Schwabe
IC Layout Engineer
The power supplies are fine now. I think there was always 3.3 V...
I put a scope on the pins and P30 gives a sad little 1.5 V spike with ~2ms decay when power is applied. This is the only sign of life...
Had my Parallax shopping cart full of stuff when my computer died [noparse]:([/noparse]... I'm really having a bad day now.
Did you check that reset is high?
If not OK, maybe the problem is somewhere else, the serial I/O.
In such cases, I'd cut the line on the PCB (just a little gap with a **sharp** knive) going from P30 to the peripheral. If the signal is OK then, search on the serial's side.
Nick
YADRO
Reset\ is high...
I just wish Digikey carried the proto boards, then I could have made just one order...
http://www.chipquik.com/
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I too was wondering why five proto-boards cost $99.75 but the 5-pack costs $100. Emailed Parallax moments ago the burning question. Methinks Prop Proto-Boards make nice sock-stuffers.
David
"Thank you, I will have this corrected. If you put in quantity 5 in the
cart it will come out to a subtotal of $99.75. If you have any more
questions please feel free to e-mail us."
I replied (in other words) to David A. at Parallax that I would like to see the 5-pack priced a bit lower than just 5X1-proto-boards at check-out. Let's see how it goes; hopefully a price break on the 5-pack in-time for Christmas! If not, the proto-board at the current price is still a pretty good deal.
Regards, David
Also, are there any partial-failure states that you've seen that were common? What sort of symptoms would occur?
darco
www.deepdarc.com/
I used a razor around the edges (I think somebody mentioned this technique) and then pried it off...·
Unfortunately, I lost one pad doing this...· It was one of the crystal pins, so I had to run a jumper wire over.
I put in a crystal with long leads because I'm not completely sure if the crystal case is floating or not...
I think this may have shorted Vdd to Vss, where Vdd came from one of the through-holes around the Prop. I'm thinking that this drew a bunch of current THROUGH the Prop, instead of around the Prop. But, that's just a guess...
I think a real power plane would help...
David
