I'm new and have a few questions
I was turned on to this device not more than 5 hours ago in a quest to do a very specific function.
I have an application that is already fundamentally and physically built on an 8051 platform. I've spent a lot of time and effort to get it completed and debugged.
Ok nuff of that:
My goal is to have my 8051 feed an ascii serial stream of data from its serial port to a "device" that can interpret the serial stream and the put it onto a CRT/LCD through composite video connection. The person that referred me after explaining my platform, told me his IC could do it, but I'd really like this propeller chip due to the speed, power, color etc etc.
I've downloaded the software and looked at the tv.spin and the simple serial.spin. I must admit, I have no idea where to go from here or how to link these two modules together to achieve my goal. I've looked at several examples. I don't understand how to draw the information onto the tv area or how to have the serial stream and parse the data. Is there any way to draw borders or to shape the TV display data? I didn't see any way to do that.
Also, how do you get this to run at 80MHz? I've yet to see a xtal beyond 20Mhz???
If these are noob questions I applogize, I just don't have the motivation to learn another complete language from the ground up (yet). I really like what I see with the propeller, just looking for a quick A to B fix for this issue.
Can anyone point me in the right direction?
Thank you
Chris
Ok nuff of that:
Thank you
Chris
I'm assuming that you want a text display. If so, there's an object called tv_text.spin that takes an ASCII string and displays it on the video screen and interprets some control codes to do things like row and column positioning and setting the current color(s). If you want complex borders or graphics, there's a separate graphics driver that also handles vector-based text. All of these drivers include demo programs that are included with the Propeller Tool.
The Propeller has a PLL (phase locked loop) in its clock circuitry that can multiply the crystal oscillator frequency by powers of 2 up to 16, so a 5MHz crystal becomes an 80MHz system clock. The Hydra and the SpinStamp use a 10MHz crystal x 8 to get the same system clock frequency.
There's not a super quick A to B fix for this. It will take some coding on your part. If the "interpret"ing is not too complex, I suspect this might take one to two pages of code to do.
In terms of hooking the serial I/O and display I/O modules together, there's a serial input routine that gives you the next character received and there are two display routines, one that takes a single character and writes it to the current display position and another that takes a string (zero terminated) and writes it to the display interpreting any control characters as it goes. There are also routines to take numbers and display them as decimal or hexadecimal data.
I'm just not understanding the object usage aspect. Like in VB, you'd place the text button, click on it, then write your code.
What I don't understand is how to link all of it together, assign the pins??? Does the programming assume that your using the pins as defacto in the demo board?
How does one debug the code that they write, just follow the compiler errors?
I guess I'll reread your section and try to connect all the dots.
I will order one chip tomorrow and create a CNC PCB prototype to test......this is how I feel right about now.....>
LOL
Thanks for the fast response.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ text : "tv_text" PUB start | i 'start term text.start(12) text.str(string(13," TV Text Demo...",13,13,$C,5," OBJ and VAR require only 2.8KB ",$C,1)) repeat 14 text.out(" ") repeat i from $0E to $FF text.out(i) text.str(string($C,6," Uses internal ROM font ",$C,2)) repeat text.str(string($A,16,$B,12)) text.hex(i++, 8)The CON block·configures the system clock, the OBJ block includes the tv_text object for use. The text.start initializes the object and indicates to output on 4 continous pins starting at pin 12, the circuit for the TV connection is availible on the Demo Board schematic located in the Diagrams,Schematics, and Images page. The text.str shows how to display static text, including ASCII control characters to the display. The section between the two text.str displays the entire built in font to the screen. The text.hex displays the incrementing variable as a hexadecimal of 8 characters long.
So it's not a difficult proposition to write a simple program where the program checks serial input and display it to the screen, in fact it's was easy enough to write a dumb terminal program that I wrote one:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 TXPIN = 0 RXPIN = 1 SERMODE = %0000 BAUD = 9600 OBJ text : "tv_text" serl : "FullDuplexSerial" PUB start 'start term text.start(12) 'start TV on pin 12 through 15 serl.start(TXPIN,RXPIN, SERMODE, BAUD) repeat 'forever text.out(serl.rx) 'wait for a byte to be received serially and output the value to the screen·
Paul Baker
Post Edited (Paul Baker (Parallax)) : 12/6/2007 3:40:59 AM GMT
the simplier fiels aer starting to make a bit of sense. I understand the con thing now and the xtal multiplier.....just like a normal computer, with cpu multipliers.....> done
I guess the code you wrote will be the minimum framework I can use to get started. I'll be ordering the chip tomorrow and will link up the serial output of my 8051 to the IC and code you provided. I hope that does the trick. Seems easy, I just wish I completely understood the spin language......and the formatting syntax. That will come with time I guess......thanks for the help......[noparse]:)[/noparse]
Chris
Paul Baker
If you're getting something like the Propeller Demo Board, it will include the TV interface and the USB to serial adapter (and a 5V and 3.3V regulator). You'll still need the 1K resistor between the 8051 and the Propeller.
Post Edited (Mike Green) : 12/6/2007 3:38:35 AM GMT
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 TXPIN = 0 RXPIN = 1 SERMODE = %0000 BAUD = 9600 OBJ text : "tv_text" serl : "FullDuplexSerial" PUB start | i 'start term text.start(12) 'start TV on pin 12 serl.start(TXPIN,RXPIN, SERMODE, BAUD) repeat 'forever text.out(serl.rx) 'wait for a byte to be received serially and output the value to the screenJust a couple of questions on the code
Why did you put the | i > is that supposed to be an argument return? And for what?
Where is the documentation for the SERMODE and what are the other options for it? No returns in the forum about it
How do I find out how the object is supposed to be analyzed? Does the tv_text know the 3 pins that create the outputs with the 3 resistors?
So many questions.....sorry
the sermode is outlined in the object FullDuplexSerial.spin, here's a reprint:
It's the 3 consecutive pins starting with the number specified (12,13,14)
Paul Baker
the line
is where you specify which pins to use for the TV output. In this case it is pin 12, and the next 2, so pins 12-14 are used.
One note..... My SpinStudio hardware can get you up and running with composite video. And now the Main Board includes a Propeller and an EEPROM for no extra cost. I was going to announce that to the forum members in the next day or 2, I am just waiting on a shipment of Propellers from Parallax. All you would need is a PropPlug to program it. Or, the EEPROMs ship pre-loaded with PropDOS. You can compile programs to a binary file, save to an SD card, and load/run with PropDOS, no PropPlug required.
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Thank you for the addition information. I'll be ordering the chip tomorrow, I have all the components to properly replicate the demo board schematic which I assume is absolute at this point with no errata.
The code snippet and the addition info was very helpful. I was reviewing the quick reference sheet for spin and asm and it seems pretty straight forward. Just not used to "starting" and object....
I'm VERY excited about this aspect of my project, it looks like it will be a perfect fit and a lot of support around this platform.....
I peeked into that fullduplex file and didn't see SERMODE but I did see the excerpt, I see how the four bits are represented as %0000 but it doesn't make sense how it references those bits from that object file since there is no similiar caller name to the function "SERMODE". Maybe it'll click later on. Thanks
Paul Baker
