Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Rfid problem — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
Rfid problem
Freqout_38kHz
13
2007-11-29 22:04
edited 2007-11-29 23:36
in
BASIC Stamp
Why use 10 name cannot display name on debug terminal. But when i'm use 6 name ok..
Untitled1.bpx
6.2K
Mike Green
23,101
2007-11-29 22:15
edited 2007-11-29 22:15
I don't see any obvious problem with the show name routine. What's happening?
sam_sam_sam
2,286
2007-11-29 23:15
edited 2007-11-29 23:15
Freqout_38kHz
I had the same problem that you are having you have to change
IDX VAR Byte to IDX VAR Word
Because
the byte index was not big enough for ALL
the Tags that
I want to use
Here is post where i ask the same thing
http://forums.parallax.com/showthread.php?p=649002
I hope this help you in what you want to do
Thanks for any
that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 11/29/2007 11:24:07 PM GMT
Freqout_38kHz
13
2007-11-29 23:36
i'ts work thank you.....
Sign In
Register
to comment.
·IDX VAR Byte to IDX VAR Word
·Because·the byte index was not big enough for ALL·the Tags that·I want to use
·http://forums.parallax.com/showthread.php?p=649002
··Thanks for any·
Sam
