Question re BS2.PWM_Set (Pin,duty,resolution)
Hi
Having a play with all the functions Martin Hebel has created..
WOOW Martin awesome the latest BS2.Functions is fantastic thanks..
Using the BS2.PWM_Set ( 8,512,10) example.. to a led on pin 8..
I can see my LED dim and go brigther as I set the duty higher and lower
so obviously the pin is doing what is suppose to be doing..
But for some reason I can't get a steady signal on my scope
What is the PWM frequency ? ·and is it very jittery...??
Cannot ·get my scope to trigger on it at all..
Has anybody used this function and shine some lite on it..
Love that Freqout call set it 100000 and she spits out 100000KHZ signal awesome..
cheers
Ron· Melbourne OZ..
Post Edited (OzStamp) : 11/27/2007 9:31:38 PM GMT
cheers
Ron· Melbourne OZ..
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Much like the BS2, the output won't be an idealistic PWM shape.· The counter mode and the overflow timing creates the necessary high vs low time to achieve the duty desired.
Thanks for the compliment, it's helped me learn Spin and counters and it's worked out well as examples in the classroom.·Much of it was adapted from other sources, such as Andy's various work.
Though sometimes I look though it and think about how I could improve it more having learned a lot since my beta tester days with Spin and the Prop.
-Martin
SelmaWare Solutions - StampPlot GUI for controllers, XBee and Propeller Application Boards
Southern Illinois University Carbondale, Electronic Systems Technologies
Yes same here.. still learning alot .. just not enough hours in the day..
Spend a few hours lately just going some thru the BS2 functions and reading alot..
We inherited a job from somebody and was asked to finish it ..
The code would work fine for 10 minutes or so ·but eventually it would crash
the Prop.. rebooting would alway's fix it..
I fell for the "ABORT"abort trap.. the syntax ABORT ( scan) would work·..
You could see the code jump to the PUB called·scan and run whatever was there...
Anyway I got frustated with it and asked for help.
Peter Jakacki here locally got me out of the POO...thnx Peter ..
We finished it off using the same BULLDOZER approach as he called it
but we got something that is now running solid..
We initially suspected faulty PSU·· ... faulty chip etc etc.
In the end it only could be the program...
We need to add some more functionality to it ..
Jeff Martins encoder object .. looks like it could be usefull for what we need.
I played with that object before and found that the READ Delta variable
seems to·act a little strange.. with an encoder standing still ( one of those volume indent panel mount
type ones .. used for volume controls..) it would still return a deviation of -1 or even +2..
Credit again to you.. also to Mr Voss I see his name mentioned thru out the
BS2.fucntions and of course also Andy Lindsay..
Cheers
Ron Melbourne OZ
