Basic_I2C_Driver SPIN OBJECT and I2C EEPROM
Hello,
I hooked up a second 24lc256 EEPROM with shared I2C lines with the one that has the Propeller code and changed the address on the pin to be a0=1 a1=0 a2=0. I tried using the Basic_I2C_Driver spin object from http://ww1.parallax.com/Support/PropellerLibrary/tabid/65/Default.aspx
obex.parallax.com/objects/26/
and it's not quite working properly.
Now, I thought that the address I was supposed to use is $A0 + 2 = $A2. The two is because of the a0=1 a1=0 a2=0 and in the 24lc256 PDF ww1.microchip.com/downloads/en/DeviceDoc/21203P.pdf page 8, I thought this was right for this type of device on the I2c bus.
Question 1:
What is wrong with my below code? It's not storing and retrieving timeMin and timeHour increments by 1 each time:
Question 2:
I found this in the SPIN driver itself. What is this for?
Frank
Question 1:
long timeDay
long timeHour
long timeMin
i2c.Initialize(28)
eepromStatus:= i2c.ReadPage(28, $A2, 2*(7*60*24)+0 , @timeMin, 1)
'' abort ' an error occured during the write
eepromStatus:= i2c.ReadPage(28, $A2, 2*(7*60*24)+1 , @timeHour, 1)
eepromStatus:= i2c.ReadPage(28, $A2, 2*(7*60*24)+2 , @timeDay, 1)
....code which is not relevant...
eepromStatus:= i2c.WritePage(28, $A2, 2*(7*60*24)+0 , @timeMin, 1)
eepromStatus:= i2c.WritePage(28, $A2, 2*(7*60*24)+1 , @timeHour, 1)
eepromStatus:= i2c.WritePage(28, $A2, 2*(7*60*24)+2 , @timeDay, 1)
Question 2:
'' CON '' eepromAddress = $7000
Frank
2) That's part of the sample code. It has nothing to do with the driver itself.
Frank
