BS2p 15uF 16V cap availability
Hi-
my understanding is that this component is a 15uF 16V tantalum cap. I'm planning on rebuilding a Stamp module on my own board, but I can't seem to find this part. Digikey, Mouser and Avnet all have it, but no one has it in stock and the minimum order quantities are 500 or 2000, depending on where you look.
Is there anywhere else I can find 5-10 of these capacitors?
Raf
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
Raf
You can't win.
- Rick
Chris Savage
Parallax Tech Support
Raf
You can't win.
- Rick
Raf
You can't win.
Other features of the LT1121/LT1121-3.3/LT1121-5 include
the ability to operate with very small output capacitors. They
are stable with only 0.33μF on the output while most older
devices require between 1μF and 100μF for stability. Small
ceramic capacitors can be used, enhancing manufacturability.
and
The LT1121 is designed to be stable with a wide range of
output capacitors. The minimum recommended value is 1μF
with an ESR of 3Ω or less. For applications where space
is very limited, capacitors as low as 0.33μF can be used if
combined with a small series resistor. Assuming that the
ESR of the capacitor is low (ceramic) the suggested series
resistor is shown in Table 6. The LT1121 is a micropower
device and output transient response will be a function of
output capacitance. See the Transient Response curves
in the Typical Performance Characteristics. Larger values
of output capacitance will decrease the peak deviations
and provide improved output transient response.
- Rick
Thank you though
Raf
You can't win.
Also, with a 5V or 3.3V output, you don't need a 16V capacitor. With a 5V output, anything from about 6V up should do.
I feel stupid asking this, but the Stamp's regulator doesn't seem like a switcher...don't those normally need inductors? Is it linear?
Raf
You can't win.
Raf
You can't win.
