Share SPI pin and I2C pin?
Zoot
I've got a Stamp project going and I'm one pin short. Two of the components in the project are 24LC32A EEPROM and '595 shift register. I was thinking that I could use the same pin for both SCL and the shift clock on the '595. I would think the pullup on the SCL wouldn't adversely affect the '595 clock input. If that would be OK, then...
What state do I need to leave SDA in when I'm done with I2C communication so that the unrelated activity when I shift out to the '595 on SCL doesn't accidentally cause an I2C stop/start condition?
Other suggestions on sharing a pin like this?
