4 servo demo, what am I doing wrong. — Parallax Forums
DgswanerDgswaner Posts: 795
edited 2007-11-25 13:25 in Propeller 1
Proto board. onboard power. it's connected correctly I can get it to move.
I had this code working on my DEMO board, but now I can't seem to get it working. it will only move to the angle specified in servo.start anything I do to the repeat loop doesn't effect it at all. I haven't modified the servo4 object at all. I've got to be missing something simple but I can't figure it out. any help would be appreciated. the servo stays on holding the start position.
thanks,
dg
{{ Demonstration of the use of the servo4 object
  08/29/2006 - Bob Belleville first version from scratch
CON
  _CLKMODE = XTAL1 + PLL16X
  _XINFREQ = 5_000_000
OBJ
  SERVO : "Servo4"
PUB go | unit0
  servo.start(500,11,0,12,0,13,0,14)
  unit0 := 1
  repeat
    servo.move_to(11,500,200)
    servo.wait(11)
    servo.move_to(11,1000,200)
    servo.wait(11)
    servo.move_to(11,2200,200)
    servo.wait(11)               'move one at a time
    if unit0                    'cycle unit 0 on and off
      servo.move_to(0,0,0)      'unit 0 no signal
      unit0~
    else
      servo.move_to(0,1000,0)
      unit0~~
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
  • DgswanerDgswaner Posts: 795
    edited 2007-11-14 20:32
    Does anyone have working code that I could look at and modify for my application? I'm only going to need to control 4 servos max. so the 32 servo object is overkill.... I think.
  • Paul Sr.Paul Sr. Posts: 435
    edited 2007-11-14 22:28
    I think you should reconsider the "32 servo object"! I just looked it over and I think it looks nice and should help you out.
    edited 2007-11-14 22:36
    being so new at spin if a little frustrating, like anything. With pbasic I know the common mistakes and can usually figure something out, but I could be staring right at the problem and not know it with Spin. but that's how it goes! This forum is a big help tho. I'll look at the servo 32 object. thanks
    edited 2007-11-14 23:22
    Dgswaner said...
    Well, the truth is, I am trailing you significantly in the curve, but I just now had it working with an HB-25 connected to a DC gear reduction motor. Worked out of the box! I think you will like it!
    edited 2007-11-15 01:45
    Thanks Paul!
    Beau Schwabe
    IC Layout Engineer
    edited 2007-11-15 04:03
    Well, it took me all of about 3 minutes to get the 32 servo object working. it's pretty slick, I'm still dialing in my limits for full movement but it's up and running!
    Thanks guys
    Post Edited (Dgswaner) : 11/15/2007 7:18:31 PM GMT
    edited 2007-11-15 23:42
    Beau Schwabe (Parallax) said...
    Thanks Paul!
    You and Dg are welcome.
    Glad I could help!
  • Glenn IrwinGlenn Irwin Posts: 6
    edited 2007-11-25 08:40
    In your code example, your move_to() and wait() calls should refer to the servo unit (0 - 4) and not the pin number. I made this mistake too. It is not pointed out clearly in the documentation.
    I am also looking to control 4 servos and I started with the Servo4 object then moved up to the Servo32. I have now moved back to the Servo4 object because it seems to be easier to use and I can turn off the servos by setting the angle to 0 (major power savings).
    I just haven't figured out how to turn a servo back on after setting the servo angle to 0 (off)
  • J.A.B.J.A.B. Posts: 13
    Dgswaner said...
    Thanks guys
    Just remember that using servo signals outside the 1-2ms range for 180 degree movement, are "out of spec". So the limit values for one servo may not work with another. You will also most likely have to calculate a new center timing, after you have found the limits.
