EEPROM direct Read/Write ?
Hi,
I'm trying to get a handle on reading/writing specific EEPROM memory locations.
I'm trying to use the Femento routines.
I've also reviewed the FemtoBasic EEPROM cmd.
But I don't know what I'm doing wrong ?
Can someone help me, it's probly somthing simple stupid
because I'm new to all this stuff.
Here's my code
CON
·· _clkmode· = xtal1 + pll16x
·· _xinfreq· = 5_000_000
OBJ
···· fsrw· : "fsrwFemto"
···· dsp·· : "vga_drive"
VAR
· long ioControl[noparse][[/noparse]2]
· byte ret_buff
DAT
buff····· byte····· "Z"
PUB mainProgram
· dsp.start(16)
· fsrw.start(@ioControl)······················· ' Start I2C/SPI driver·
· fsrw.writeEEPROM(28,@buff,1)
· fsrw.readEEPROM(28,@ret_buff,4)
· dsp.hex(byte[noparse][[/noparse]@ret_buff],5)·
I've tryed some different things, but I can't get it to work.
Thanks for the help,
-Areal
I have a tree growing out of my head, but
what do you expect ? I'm a programmer.
Here's my code
CON
OBJ
VAR
· byte ret_buff
DAT
PUB mainProgram
· dsp.start(16)
-Areal
Don't forget that the EEPROM write cycle takes about 10 milliseconds to finish. Try the following to write/read the end of the 32K boot EEPROM:
Note that in your code, you're trying to read 4 bytes into a 1 byte variable.
That really helped me to learn somthing [noparse]:)[/noparse]
Thank you so very much !
-Areal
I haven't really tested it. It was written to run at either 100kHz or 400kHz bus speeds and seems to have intermittent problems at 400kHz (I've never figured out why) so the Spin interface routines always use 100kHz. For large block reads, it ought to achieve 10k bytes per second. For small blocks, the setup overhead (calling the routines, addressing the device, etc.) would sharply cut into this.
Why use 18 for i2cBootSCL ?
i2cBootSCL = 28 ' Boot EEPROM SCL pin
bootAddr = i2cBootSCL << 18 ' Address of boot EEPROM
QUESTION:
If I place an EEPROM on a different pin, and I don't want it to be connected to the first one, say... 14
Would I still use 18 when I shift ?
I want a second EEPROM, but I do not want it chained from the first one.
(completly independent from the first boot eepeom)
E.G
i2cEEPROM_2_SCL = 14
EEPROM_2_Addr = i2cEEPROM_2_SCL << 18 ' Address of a different EEPROM
Or must I use SPI and different read/write routines ?
-Thanks
Post Edited (Areal Person) : 11/11/2007 6:43:59 PM GMT
As you showed, if you have additional EEPROM on pins 24/25, you use 24 << 18 as part of the address to designate the pins used.
I've heard talk about an SPI engine ? is that the sdspiFemto.spin file ? Or is there somthing I'm missing ?
I looked through the Prop OS and found some code that does a transfer of data to/from Vinculum USB Host in SPI mode
in the osMassStorage.spin file.
Do I have the SPI Engine, or am I missing somthing ?
I need to start working with SPI, I've only ever hooked up 1 chip, I think I used SPI to do it?
It was the TLC5940, I clocked a datastream in and latched it into the register by sending a rising edge of XLAT. (Is that spi ?)
Thanks for all your help,
-Areal
-Areal
could you give me some advise/pointers on what I'm doing wrong, I CANT GET IT TO WORK
I tried to setup a different Pin I/O Pair so I can use a second EEPROM
on my demo board. (I need to use a different pin pair). I understand what you said about the 512 segments
in the 8meg block per pin I/O pair.
Does the memory start over at 0000 for each pin pair, or does it continue ?
I've tried both addresses, could you offer me an address for a second pin I/O pair
just so I can check it ?
Also...(I also tryed a fram chip), then went back to a second 24LC256 to keep it simple.
I did this ...
24LC256.A0·->·VSS
24LC256.A1·->·VSS
24LC256.A2·->·VSS
24LC256.VSS·->·VSS
24LC256.VCC·->·3.3vdc
24LC256.WP·->·VSS
24LC256.SCL·->·PROP.P2···· (Lower even pin for the clk)
24LC256.SDA·->·PROP.P3···
Then, I added this under the bootAddr stuff in sdspiFemto.spin
·i2cFram1SCL = 2
·Fram1Addr·· = i2cFram1SCL << 18
I also updated fsrwFemto like this...
con
·· bootAddr· = ldr#bootAddr··· ' Address of boot EEPROM (in I2C address space)
·· vbase···· = ldr#vbase······ ' Length of Spin program loaded (# longs * 4)
·· Fram1Addr = ldr#Fram1Addr·· '· I ADDED THIS LINE HERE !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Then I did this in my spin code.
The checkPresence function always returns true NO matter what I do.
tmp := false
tmp := fsrw.checkPresence($7FF0 + fsrw#Fram1Addr)
· if tmp
··· dsp.str(string("Found the FRAM chip !"))
· else
··· dsp.str(string(":ERROR: FRAM NOT Found!"))
· dsp.str(string(" ",13," ",13))··
· fsrw.writeEEPROM($7FF0 + fsrw#Fram1Addr, @buff, 1)···· '·I ALSO TRIED $d5ac + fsrw#Fram1Addr ETC...
· waitcnt(clkfreq / 100 + cnt) ' wait 10ms
· fsrw.readEEPROM($7FF0 + fsrw#Fram1Addr, @ret_buff, 1)
· dumpRAM(@ret_buff,4)
' THIS FUNCTION WORKS FINE !!
' Dump ram memory
PUB dumpRAM(addr,size) | i, c, p, first, buf0, buf1, buf2
'' This routine dumps a portion of the RAM/ROM to the display
'' The format is 8 bytes wide with hexadecimal and ASCII.
·· addr &= $7FFFF
·· first := true
·· p := addr & $7FFF8
·· repeat while p < (addr + size)
····· if first
········ dsp.hex(addr,5)
········ first := false
····· else
········ dsp.hex(p,5)
····· dsp.out(":")
····· repeat i from 0 to 7
········ byte[noparse][[/noparse]@buf0][noparse][[/noparse]i] := " "
········ if p => addr and p < (addr + size)
·············· c := byte[noparse][[/noparse]p]
··········· dsp.hex(c,2)
··········· if c => " " and c =< "~"
·············· byte[noparse][[/noparse]@buf0][noparse][[/noparse]i] := c
········ else
··········· dsp.out(" ")
········ p++
····· buf2 := 0
····· dsp.out("|")
····· dsp.str(@buf0)
····· dsp.out("|")
····· dsp.out(fReturn)·
Thanks for any help you can offer, I'm trying to learn how to hook
memory chips.
-Areal
