How to power PINK module
I'm new, so sorry for such a basic question.· How would you hook up and power the PINK module to a development board?· I have a Homework board (not tied to it, can move to something else like BOE if needed), and it says in the manual that the I/O pins provide 20 mA, while the PINK module says it needs 350 mA.· I dont want to damage my board before I even get a chance to play with it!·
Thanks!
Thanks!
I got this one off eBay for about $15 (including shipping), but it's pretty versatile. I just stripped the leads on an old wall wart and connected it to the power supply board (it can use AC or DC).
Also, it might be useful to know that the J8 connector on the PINK / NetBurner board is an auxiliary/extra power connector (this is not in the Parallax documentation). You can power the board with 5 volts there (must be regulated), just make sure you have a common ground with your Basic Stamp. The pin out is :
(+) +5 Volts <-Must be regulated!
(-) GND
Either or both +5 volt connections will work, this layout just makes it harder to connect with reverse polarity.
This is how the PINK in the picture is powered. Be very careful about polarity, you don't want to blow up your PINK, and it needs to be regulated 5 volts! No wall wart or AC adapter here! Unless regulated!.
For a while my PINK will be running here:
75.65.162.169
- Rick
Edit: You want center positive on a 2.1mm plug for most Parallax products
- Rick
Post Edited (RDL2004) : 11/11/2007 12:10:07 PM GMT
PM me if I can help.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
- Rick
