Understanding TV.SPIN Initialization
I have only just started examining Graphics.Spin and how it initializes the TV.Spin object.
For the question, the following is excerpted from Graphics.Spin.
Why is the longmove necessary?
Shouldn't you be able to pass the address of tvparms in the DAT section, as in "tv.start(@tvparms)" ?
Lucidman
long tv_status '0/1/2 = off/visible/invisible read-only long tv_enable '0/? = off/on write-only long tv_pins '%ppmmm = pins write-only ... PUB start | i, j, k, kk, dx, dy, pp, pq, rr, numx, numchr 'start tv longmove(@tv_status, @tvparams, paramcount) tv_screen := @screen tv_colors := @colors tv.start(@tv_status) ... DAT tvparams long 0 'status long 1 'enable long %001_0101 'pins long %0000 'mode
Lucidman
Graphics.Spin could have two tv objects like the following...
·...right?
But each would need separate control blocks ... right?
What is keeping you from setting up two control blocks in the DAT section and not use up space in the VAR section?
Lucidman
Thanks for your patient answers.
Lucidman
I really do not know what I should admire more: Mike's patience, or his knowledge and experience....
Admire them equally as he is a true Gem.
