Return from Interrupt After Sleep (Using WKEN)
Zoot
If you enable an edge-detect wakeup on a pin (using WKEN_B), after the ISR runs, will the main program resume with the PC set to the instruction following SLEEP?
Quasi-related -- say I'm running an RTCC ISR, but I want to shut down the RTCC ISR, enable wakeup from a pin-driven interrupt, then sleep, then restart the RTC ISR after wakeup,·would I do something like the following:
And if I didn't need to seize control of the RTCC interrupt upon wakeup, could I leave it at:
The project I'm working on doesn't need to deal with the wakeup in the ISR.
Last, one thing I *think* I'm clear on with WKPND -- whenever you write to WKPND, you are *always* swapping with W?
So
MODE $09
MOV !RB,#%0000_0000
would put current WKPND into W and put 0 in WKPND? and
CLR W
MODE $09
MOV !RB, W
would effectively do the same thing, and
MODE $09
MOV !RB, someVar
would put someVar into WKPND, and put WKPND into W, leaving someVar in it's original state?
MOV !OPTION,#%1100_1000 ; turn off ISR MODE $09 ; clear pending MOV !RB,#%0000_0000 MODE $0A ; falling edge detect MOV !RB,#%1111_1111 MODE $0B ; enable wakeup int from button RB.4 - active low MOV !RB,#%1110_1111 SLEEP ; return below after int? MODE $0B ; turn off wakeup int MOV !RB,#%1111_1111 MODE $09 ; clear pending MOV !RB,#%0000_0000 MOV !OPTION,#%1000_1000 ; restore original RTCC settings
MODE $09 ; clear pending MOV !RB,#%0000_0000 ; default MODE $0A ; falling edge detect ; default MOV !RB,#%1111_1111 MODE $0B ; enable wakeup int from button RB.4 - active low MOV !RB,#%1110_1111 SLEEP ; return below after int? MODE $0B ; turn off wakeup int MOV !RB,#%1111_1111 MODE $09 ; clear pending
So
MODE $09
MOV !RB,#%0000_0000
CLR W
MODE $09
MOV !RB, W
MODE $09
MOV !RB, someVar
See attached appnote how to distinguish between different
types of reset.
regards peter
"MOV !RB,W" will always swap the values. There is no such instruction as "MOV !RB,#0" or "MOV !RB,someVar", they are compound instructions.
So "MOV !RB,#0" becomes "MOV W,#0" & "MOV !RB,W"
And "MOV !RB,someVar" becomes "MOV W,someVar" & "MOV !RB,W", so no the WKPND values does NOT end up in someVar unless you do "MOV !RB,someVar", then "MOV someVar,W"
You have to watch those compound instructions, they are handy, but they can really trip you up.
Bean.
www.hittconsulting.com
A few points I wish to have clarified then:
- an input wakeup, then, is essentially a "soft" reset, and I can take advantage of unchanged registers and the PD and TO bits to decide what to do differently from a hard reset (if I choose), keeping in mind that some registers will be unchanged from before the sleep state (rather than undefined as they might be on powerup).
- since I use SX/B for the startup and main portions of my code, and ASM for the nitty-gritty, I would presume that an input wakeup will skip the powerup portion of SX/B's startup code
- in SX/B if I write:
WKPND_B = %0000_00000
In my src file I see:
MOV !RB,#%0000_0000
Bean, it sounds like you are saying the above is really a compound instruction, e.g.:
MODE $09
MOV W, #0 ; set up W for swap
MOV !RB, W ; any move into WKPND swaps WKPND and W
This is done by the assembler?
If you are using SX/B then make sure you use the NOSTARTUP option on the PROGRAM line. Like "PROGRAM Start NOSTARTUP" this will prevent SX/B from clearing all the variables duing a wake-up.
A wake-up input only has an effect if the SX is in sleep mode. Otherwise it does nothing.
Yes, the ONLY instruction that exists to change !RB is "MOV !RB,W" so anything else is a compound instruction that get expanded by the assembler.
Look at my "Magic 8 Ball" code for an example of using the Watchdog wake-up. Most will apply to using a wake-up pin too.
http://forums.parallax.com/showthread.php?p=670447
Bean.
