What is a good design for a Battery Monitor
Has anyone build one or can anyone recommend a good design of a battery Monitor (fuel Gauge) , Maybe point me to a schematic that they have used with good success.
I don't want to drain a lot of battery power monitoring the battery . [noparse]:)[/noparse]
Any help or suggested reading would be greatly appreciated.
Best Regards,
Eric
Best Regards,
Eric
Depending on what you want to do and what type of battery you're using, maybe a simple micropower comparator will work along with some kind of micropower voltage reference. Maxim/Dallas has all sorts of very low power analog to digital converters, op amps, comparators, voltage references, etc. Take a look at their website.
Post Edited (Mike Green) : 11/2/2007 3:45:03 PM GMT
I'm building a 5V / 3V Buck Regulator PCB
http://forums.parallax.com/forums/default.aspx?f=15&m=222582
I though that I would integrate a battery Monitor into it.
The Battery a 12 volt System probably Lead Acid.
Eric
ELECTRONICS ARE SO MUCH FUN!
http://www.uoguelph.ca/~antoon/circ/batmon12.htm
http://www.reconnsworld.com/power_lm3914battmon.html
I've also gotten some good feedback and ideas on Yahoo's Electronics Group Forum... http://groups.yahoo.com/group/Electronics_101/message/41279
I don't like the one at Reconnsworld as it suggests a separate 12 volt source to power the circuit.
I'll have a look at your last link in Groups.
Let me know what you come up with and I'll to the same.
Eric
Post Edited (SailerMan) : 11/2/2007 5:43:55 PM GMT
search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=296-2218-5-ND
My gas gauge is a duplicate of the sample LED circuit in the datasheet, but uses an IO pin to "push the check button" and the LED pattern is displayed by LEDs. The next step is to get it to read the LED status as a 6 bit number.
(IE: 50% battery=3 LEDs on= 000111). The BQ2010 can communicate but the datasheet is pretty intense for me to dig into now.
I probably won't finish the gas gauge until I finish my wireless battery charger circuit. I'll be starting a thread on that as soon as I finish the prototype. This weekend hopefully.
~~ dRu ~~
