Proto Board with 12V Power Adapter
Okay the specs list the proto board as using a 6-9VDC power input, the 1086-5V specs list that is can handle up to 20V (I believe). Would it be safe to run the board off a 12V power adapter without adding any type of heat sink?
I think I've got my place of work to buy some proto boards for some projects but I wanted to verify if we could use the abundance of 12V 1Amp power adapters we have sitting around. Also any projects made would be running 24/7 in most likely a sealed enclosures.
Thanks for any help
Thanks for any help
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Which means it is not wise to dissipate more than 3W, though this most likely will even need a heatsink.
Though it is not a proportional calculation, I should say you can easily draw 1W/7V = 150mA @ 12V without a heatsink.
Note that the total heat inside your box will be 12V*current - absolutely independent of how you use this power. It would be 12W @ 1A which is definitely too much without good airflow and 1.8 W @ 150mA which I should say is acceptable
Graham
Thanks guys.
Case in point, when I plug in my PropNIC, with a 9 volt wallwart, the regulator gets very hot quickly. The ENC28j60 chip itself draws 250mA. When I use a 6 volt supply, the regulator barely gets warm.
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
It works with 30V of course, when you draw just 100mA!!
To remind you:
V = R*I Ohm's Law
P = V*I Power dissipation
As you said DeSilva, basic high school Ohm's law stuff (and from there power calculations) although 30V@100ma is a fire starter!
Doesn't anyone use switch-mode regulators anyway? 5V@1A from an 8-pin smd running from 30V with no heatsink.
*Peter*
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
With care you can un-solder and replace with a 50V cap....
J
See, that wasn't hard.
*Peter*
Ahhh, the datasheet, yes. What's missing from the datasheets is the safe operating area region (SOAR) information but understandably that gets complicated with all the variable conditions. Still, the datasheet provides the device characteristics which via some basic maths gives us an idea whether it is up to the task. The graphs are also very helpful and reading the footnotes should be mandatory.
Phil:
Aren't those things so cheap! Still, they have a habit of giving you a bite due to the cap between the mains neutral and dc common. Anyway many times commercial equipment has to operate from a system supply of +12 or +24V and plug packs (that's what we call them) in these installations are troublesome, they take up room, require a mains connection, need to be secured (whoops) etc.
*Peter*
To paraphrase a proverb "if you say enough you're sure to stuff up"
..and if we didn't say much then what fun would that be?
I tidied up my little switcher pcb and made it smaller. I will probably do a run of them off my next proto panel. They are so small that I'd probably get 50 just filling up the spaces. On the switcher module I have allowed for a small trim resistor to adjust the voltage plus I may dip the modules in a conformal coat. They're not really any larger than a 7805 TO220 pack plus they don't need a heatsink and run about 80% efficient.
*Peter*
Wonder if Peter's switch mode supply would save battery life...· I'm a little discouraged by how hot the 3.3 V regulator on the Proto board gets...
Message me your address and I will send some freebies to you in a week or two.
*Peter*
*Peter*
We're not using a wall wart, as our application is for automotive. So we put an extra 7808 regulator in there with a big heat sink. No problems.
I still don't understand the design decision to feed to the 3.3V regulator from the 5V regulator. For another project, I designed a board to use the propeller and I also had to use dual voltages because I had video switchers that run on 5V. I used a 317 regulator for each voltage and each is fed from the 12V input. No problems here even without heat sinks.
The more I know, the more I know I don't know.· Is this what they call Wisdom?
*Peter*
David
Peter,
Is that price for "fully populated" boards ready to run?
