Soldering Station Question
Based on threads posted here, I have purchased a temperature controlled soldering iron station to use with my STAMP projects. With this station was an iron holder that had what looked like a bright gold colored brillo pad. I assume this is used to clean the iron's tip. Could someone tell me how to properly use this item? Thanks.
There's nothing like a new idea and a warm soldering iron.
~~~~~~~~~~~~ from Hakko's page for the FP-102 Soldering Station:
Cleaning wire for the 599B, 601. Made from coils of brass. Cleans the soldering iron tip without water! The HAKKO 599B tip cleaner is made from coils of brass. It cleans without water! Simply plunge (stab) the iron tip into the coils to clean the tip. The wire is softer than the tip plating yet harder than the oxidation that forms on the tip. It will not reduce the tip temperature. A great alternative to the conventional damp sponge.
side note: saw this today........http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96531
$99 digital soldering station. I am buying one to validate it's quality against the $600 stations we have (Ersa i-Con)
~~ dRu ~~
Please post the results of your tests!
- Stephen
In other words, don't let the iron sit (hot OR cold) without a nice big blob of solder on the tip.
This has made my tips last alot longer.
Bean.
Post Edited By Moderator (Chris Savage (Parallax)) : 11/2/2007 3:47:01 PM GMT
my old mentor said the blob also helped coat the tip to reduce oxidation when it was cooling.
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
www.circuitspecialists.com/prod.itml/icOid/3528
It came with the 'brillo' pad. I have been using it for about a year. It works fine. I use a different technique with the pad. I sort of jab the point into it. If I swipe it like you do a wet sponge, it shot the solder everywhere. It comes out clean. I too 'load' up the tip before shut down like Bean said.
HTH, Chris
just noticed same price and better picture at Howard's
www.howardelectronics.com/xytronic/137ESD.html
Post Edited (CCraig) : 11/1/2007 5:21:58 PM GMT
