detecting specific sound frequency
I'm working on a combat information center automation project. One of the things we are doing is a sound tract of sound effects and people speaking. Currently, the plan is to play individual sound files directing them to a BS2 with a group of relays (currently seven of them) that would direct the sound to various speakers; the stamp would receive a command from the controlling PC letting it know which relay to close just prior to the sound file playing.
But, working with all these individual files (maybe 50 or 60) would be a pain. Now I'm thinking keep all the sounds in one file and put in high frequency sound signals that the stamp could recognize and close the appropriate relay when it gets the signal.
Is there any way for a stamp to read various high frequency sounds and flip a switch based on which frequency is received?
-Erik
-Erik
There's nothing like a new idea and a warm soldering iron.
http://www.circuitdb.com/circuits/id/162
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 11/3/2007 8:27:26 AM GMT
-Erik
The simplest way to use the '567 is to take the lock signal (pin 8) into a single Stamp pin. That pin will go low when it is locks onto a valid tone, so an presence/absence binary code on the tape could select the voice file. The tone can be high above the audio range if the equipment will support it.
The FSK as Phil suggested could potentially be more reliable. It think it requires more components and processing in addition to the lock indication, to sense the voltage on the loop filter or to count the lock frequency.
Tracy Allen
www.emesystems.com
