Can P30 drive high?
Why is there a pullup resistor on P30(TX to PC) on the propstick? is this pin "open drain"?
i fixed the intermittent "propeller lost" fault on my dev board(homemade) by adding a pullup resistor. i can only assume that this is due to the pins output driver being open drain, if this is so, why is it?
I hear and I forget. I see and I remember. I do and I understand
-Confucius
-Confucius
P30 like all the port pins are programmable and these pins are all inputs (floating) when the prop is reset which can easily generate false tx data without a pullup.
*Peter*
-Confucius
