If Then doesn't compile corectly
When I use multiple IF Then - Else - EndIf statements the compiler messes up the jump locations.
usually by reusing Else_0 and/or EndIF_0. This causes a ERROR #2. I can correct the list file and
it runs correcty. I've had this problem with multiple programs including the Bit manipulation
functions that I downloaded from this forum. The fact that·others are not·mentioning it,
makes me think it might just be my software.
go figure, thanks, neely1·
Bean.
My goal is to live forever...Or die trying.
www.hittconsulting.com
In the KEY1 code·I did not use the "optional" ELSE statement and the compiler
added them all with the same label.
In KEY2 I added the ELSE statements with similar results.
In KEY3 I corrected the·asembly code and added it to my basic file·as a work around.
Attached: KEY1.SXB, KEY1.SRC, KEY2.SXB, KEY2.SRC,·KEY3.SXB
That should take care of the problem.
Bean.
