Portable Pocket Size Debug Terminal Window (no PC)
I have a project that a BS2 will work great for, but will probably need some debugging/monitoring while testing it in it's working environment. I'd like to be able to use the same debug messages that I make use of while it's on my workbench. What would it take to connect an SX to an LCD and program it to interpret the serial debug data from my BS2 and show it on the LCD? This would allow me to have a pocket size debug window that I can connect to my project when needed. I have all the necessary parts and just started reading about the SX/B compiler.
thanks
~~ dRu ~~
thanks
~~ dRu ~~
EDIT: we wrote at the same time.
--DFaust
It has built in video, and there are code objects for video & serial comms available for download in the Propeller Object Exchange.
Here is a good way to use it...· A serial LCD emulator.
All you have to do is use SEROUT commands to the PALM/Handspring and you have a place to send DEBUG messages.
http://palmorb.sourceforge.net/
I realize that using an SX would be more flexible in the long run... but this is a rather neat piece of code.
There's nothing like a new idea and a warm soldering iron.
I was thinking of using a small case that I already have. (Polycase VM-24) and so a 4x20 LCD will be perfect.
The Palm idea is very good. I have an old NEC Palmtop that runs Windows CE 2, so I'll have to see if it has a terminal program. It does have a serial port. I'll have to dig it out of my junk.
Does anyone know the specifics of the serial data that comes out from the debug command? I assume that I can try this out between my BS2P40 and BS2 homework board to figure things out.
~~ dRu ~~
Here's more info: http://forums.parallax.com/showthread.php?p=679308
Although I can't personally assist you with Propeller code (I don't have one, but have been debating buying one), I don't think you'll end up without help.
As for DEBUG, it's a variation of the SEROUT command tied to pin16. I think it's basically a wrapper to make it easier than going through the whole SEROUT parameter list for every debug statement.
You are exactly right about the debug command. I took a step back and looked into my Syntax/Reference manual and it explains the Debug command's workings as a "packaged" SEROUT command (page 169, (173 in the PDF)), so I think making a BS2/LCD combo act as a terminal window should be very easy. The LCD AppMod www.parallax.com/detail.asp?product_id=29121 is ideal, hopefully the small LCD won't be too much of an issue.
I did find my NEC Palmtop and was able to get it to boot up. It runs Windows CE 2.0 and has a terminal program. However, the serial port is a special connector on the side that plugs into a cradle. The cradle has a DB9. So either I carry the cradle with it or dismantle the cradle to harvest that mating connector. I have to dig out the cradle tonight to try it out.
~~ dRu ~~
If I were doing this myself (and I have built a few projects combining serial processing and LCD screens) I would take the time to learn how to program the SX to process the serial data in the background using interrupts. This takes only a little more effort to configure but insures you will not miss any incoming characters while sending data to the LCD.
Post in the SX forum if you decide to go this route.
- Sparks
