HB-25, fans questions
I have a pair of HB-25's that I am trying to mount in my bot. the motors are these
http://www.lynxmotion.com/images/data/ghm01.pdf
the question I have is about the fans attached to the HB-25's.. do I really need them? the doc for the motors says that at max load we they will only be pulling 233 mA.. which doesnt make since because the graph above says 1.8 amps.. at any rate, do I really need those fans for this small motor?
the HB's are supposed to be rated for 25 amps and if I were using motors that could pull even half of that I wouldnt even consiter asking this question.
oh and there are 2 of these motors per HB-25. so according to the graph, at the most the motors I have will be pulling 3.6.. I think that is like 14.5% of 25 amps. so do I need the fans for 15 % of max?
thanks guys.
IC layout designer
Austin Texas
thanks guys.
IC layout designer
Austin Texas
Save the HB-25's for that bigger robotic project with the bigger motors (>10A\side) and use a Sabertooth 2X5 RC motor controller to control the GHM-01s.
I have successfully used the 2X5 with the GHM-04s on a 4WD1 Rover with no problems.
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
IC layout designer
Austin Texas
IC layout designer
Austin Texas
The current draw is at max where everything else (but the load) drops to zero. The maximum current still does not look that high and the HB-25 has thermal overload protection. I would probably give it a try, but I would use small motor fuses on the HB-25s.
- Rick
IC layout designer
Austin Texas
(forgot attachment)
Chris Savage
Parallax Tech Support
Post Edited (Chris Savage (Parallax)) : 10/23/2007 9:49:30 PM GMT
IC layout designer
Austin Texas
Sure I have more pics…This thing is still being tweaked but the specs will be posted once complete.
Chris Savage
I have one of the Thermal Sensor Arrays (TSA) mounted on a Lynxmotion 4WD1 using one of the Parallax PING))) servo brackets and servo.
I adapted Steve Norris' TSA PIC software to work with a BS2p and presently have the 4WD1 tracking warm bodies around the house.
TCIII
Chris Savage
