PropNic Online
My Spin Studio PropNic is up and running with TCP / IP 'Stack' written by Harrison Pham
You can test it with this link http://96.232.169.180:88
Nice work!
Oldbitcollector
Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
— Calvin, of 'Calvin and Hobbes.
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Are you planing to expand the TCP/IP stack? A fully-featured web (http) server would be a brilliant addition to the object exchange.
"... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." -
"If Python is executable pseudocode, then perl is executable line noise."
"The best accelerator available for a Mac is one that causes it to go at 9.81 m/s2."
"My software never has bugs. It just develops random features."
"Windows isn't a virus, viruses do something."
"Programmers are tools for converting caffeine into code."
"Enter any 11-digit prime number to continue."
I sent a PropNIC to Harrison(he wrote the software you see in the online demo) to help him with developing code. He was using a Demo Board with the ENC28J60 and all resistors and caps on the breadboard, all plugged into a hacked NIC. As you can probably tell, it was a PITA to hook all that up everytime you want to sit and write code. Now that he has a PropNIC, he just plugs it into the breadboard of his Demo Board, hooks up a couple jumper wires, plugs in his ethernet cord, and start coding. Much easier.
Hope to see some more good code soon!
Brian
SD card Adapter
A real webserver (with sd card support) would be an awesome addition. Unfortunately that project is low on the priority list since I would have to rewrite most of the code in order to support a true tcp state machine along with multiple packet support.
I figure it is more important to release a telnet <-> FullDuplexSerial emulator/driver since it seems people are more interested in serial cable replacement than web interfaces. It would also give you the chance of writing your own http handlers (although it wouldn't be as fast since the api layer would slow it down by probably a ms or so).
Harrison
Oldbitcollector
