How to use Basic Stamp to actuate the piezoelectric film to excit the structure
Hi
My idea is use Basic Stamp to actuate the piezoelectric film to excite the structure.
Then use other piezo film to detect the signal.
My question is, I don't know if base on the purpose, What components that i should buy to implement this device.
I have Board of Education Full Kit Serial and USB compatible now, but i don't know what else i could buy for this project.
By the way, i am not a EE background,so anybody can help me please ?
Thank you very much.
wintonlin
wintonlin
Or i should post in other forums
wintonlin
--DFaust
I use LM393's for my acoustic lights and a small piezo buzzer (CEP-1110) for the pickup. I use a 10K pot to ground to adjust the sensitivity.
You can not use a piezo that has electronics on it like a radio shack piezo buzzer that runs on 12V, there is a tiny circuit on those. Also the magnetic buzzers dont work very well either.
Check out www.MSIUSA.com they have lots of information on piezo sensors.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
A little more information from you about your exact application will enable people to help you better.
Thanks for all your reply.
I have the Piezo Film Vibra Tab Mass now.
Yes, My application is like used the Piezo Film "in reverse" to generate vibration.
I know whether a piezo actuator would be adequate to "excite the structure depends on the structure's size and stiffness, among other characteristics. It is very important.
But now, i just can do the simple things that to generate vibration via in reverse the piezo.Then i can test the adequate of piezo actuator in next step.
So, If i want to used the Piezo Film "in reverse" to generate vibration.
Whats any other components should i buy for my purpose.
Others may have more suggestions. I haven't actually tried what I suggested, but it sounds reasonable.
As to actual values for the illustrated components, you'll just have to experiment. I haven't built the circuit, so I can't make any recommendations.
I Will try that all you mentioned.
If i success, i will post here.
wintonlin
Tracy Allen
www.emesystems.com
