Need help with my temp sensor circuit
I am designing this temp sensor circuit that amplifies 2-4V from an LM235AH. My current problem is that I had to make a voltage divider R3 – R4 to take the 2 – 4 volts “range of lm235AH” down to 1 – 2 volts before going into the amp.
My question; is there a better way to do this. I want to amplify the range of 0 – 5 volts but I can’t seem to get the 2 minimum from the lm235 volts down to 0 volts.
I would then run the voltage into a A/d and into the propeller for further control. Any help would be appreciated.
My goal is to live forever...Or die trying.
www.hittconsulting.com
- Sparks
The idea, I thought, would be offsetting the voltage out of the lma23ah from [noparse][[/noparse]2 - 4] to [noparse][[/noparse]0 - 2]. Once the offset is accomplished with [noparse][[/noparse]R3 and R4 voltage divider] I could then run it through an op-amp that amplifies it from 0v - 5v thus resulting in a wider reading for the a/d converter [noparse][[/noparse]gaining more precise readings like 10.02c].
The a/d would then run into the propeller so that i can apply a PID closed loop program to control temperature with a heater.
It seems to work on paper but before i build the circuit i wanted more input from more experienced people.
After typing this i am wondering if there is a such thing as an offset amp circuit? time to google!!!!
- Rick
- Rick
