Comunication
So hear the problem i finaly have everthing together and the program is written. i plug it in and low and behold the comp is convinced that the serial port is in use. wtf. so i call tech and after awile we come to the conclusion that the prot is dead. is there anything to do?
Also, look through the control panel and device manager, and make sure your ports are configured correctly. Another good check is modems - some modems "claim & lock" a port, refusing to allow anything else to use it.
That's the best way, and don't always trust tech support!
I should know, it's my job!
Flying is simple. You just throw yourself at the ground and miss.
"I think computer viruses should count as life. I think it says something about human nature that the only form of life we have created so far is purely destructive. We've created life in our own image."
Stephen Hawking
1) The serial port driver on the PC (usually part of Windows). This includes any I/O drivers for USB to serial adapters if you're using them.
These are supplied by the PC manufacturer or the USB to serial adapter manufacturer. Not all USB to serial adapters are alike as has
been mentioned. Ones known to work are those from Keyspan and those from FTDI (which are also sold by Parallax).
2) The board the Stamp is mounted on may be involved. Look at the schematic of the Serial Board of Education. There's a jumper from
DB9 pin 6 to pin 7 for the Stamp Editor to tell that a Stamp is there. The Stamp itself will echo any received information back to the
PC and the Stamp Editor will check for that as well. On the USB version, RTS is also connected to DSR on the USB to serial adapter chip.
3) Proper power has to be applied to the Stamp since the Stamp and the Stamp Editor have to have a conversation to tell the Editor which
model Stamp is there.
sadaosworkshop.tk
sadaosworkshop.tk
