Error 30 .scr file
Error 30 overwriting same counter location
When I debug my SX/B program I get the above error in the SCR file generated.
Does anyone have a clue to what needs fixed?
You either have code before an interrupt keyword, or you have more code than will fit in the device.
Bean.
My goal is to live forever...Or die trying.
www.hittconsulting.com
'Variables - ops, ms, hs, ts, sec01
' Unknown commands- COMPARE
DEVICE SX28,OSCHS3, TURBO, STACKX, OPTIONX, BOR26 ' HIGH SPEED OSCILLATOR BOR26 Brown out reset
IRC_CAL IRC_SLOW ' TURBO RUNS 4X FASTER THAN COMPATIBILITY MODE.
freq 40_000_000 ' IRC_CAL calibrates the internal oscillator. SETS THE INTERNAL OSCILLATOR TO IT'S SLOWEST VALUE
ID "TIMER" ' SETS THE STARTING POINT OF THE PROGRAM FOR THE ASSEMBLER
' 50 kHz
' IO Pins
' Seg_Map VAR RB 'display segments (anodes)
_PARAM1 VAR Byte(1)
display VAR Byte(4) 'array size 0 to size-1
TIMER
'Clock VAR BYTE(3)
ms VAR Byte(1)
hs VAR Byte(1)
ts VAR Byte(1)
sec01 Var Byte(1)
DigPntr Var Byte(1)
DigCtrl Var RC
VARIABLES
ops VAR Byte(1)
Go VAR Byte(1)
RA0_CLEAR VAR Byte(1)
RA1_START VAR Byte(1)
steps VAR Byte(1)
M_STOP VAR Byte(1)
M_Run VAR BYTE(1)
' CONSTANTS
Yes CON 0
No CON 1
' THE COMPARE STATEMENT SETS RB.1 AND RB.2 AS INPUTS AND SETS RB.0 AND _PARAM1 TO 0 IF RB.1 > RB.2.
' So if the opt isolater is blocked RB.1 > RB.2. The LED lights and the timer stops due to _PARAM1 going high and
' setting to G0 = M_Stop
TRIS_B = %00000111 'CATHODE PINS SET TO OUTPUT Register B; Rb.0 Rb.1 Rb.2 are inputs Rb.3 thru Rb.7 are outputs THIS COULD BE WRONG
PLP_A = %00000011 ' pull up the unused pins on RA. Ra.0 & Ra.1 the weak pull up resistor is disable.
COMPARE 1, _PARAM1 ' STARTS THE COMPARATOR IN MODE 1; MONITORS rb.1 AND RB.2 OUTPUTS TO RB.0 to see if the optp isolator is blocked
' adjust Potentiometer to fine tune comparison.
PROGRAM START
Segments PIN RC OUTPUT '
'Seg_Map = %00000000
INTERRUPT 1000 'Rate 1000 ' CHECK ISR EVERY MILLISECOND
' ms=%00000000
' GOTO INT_HANDLER
INT_HANDLER:
IF ops <> M_RUN THEN GOTO Next_Digit 'OPS HOLDS THE CURRENT THREE STATUS OF TIMER -
' STOPPED AND CLEAR, RUNNING AND STOPPED
Update_Clock:
INC ms
IF ms = 10 THEN ' CHECKS TO SEE IF WE NEED TO WRAP BACK TO ZERO
ms = 0
INC hs
IF hs = 10 THEN
hs = 0
INC ts
IF ts = 10 THEN
ts = 0
INC sec01
IF sec01 = 10 THEN
sec01 = 0
INC sec01
IF sec01 = 6 THEN
ops = M_STOP ' stops timer
ENDIF
ENDIF
ENDIF
ENDIF
ENDIF
Next_Digit: ' Defines which LED is being cycled
INC DigPntr
IF DigPntr = 4 Then '4 was numdigits believe this routine looks for display (4), the number of LED, then resets DigPntr
DigPntr = 0
ENDIF
Update_Seqs:
Segments = %00000000 ' clears the LED for next digit creates a crisper display.
READ DP_Map + DigPntr, DigCtrl ' DP_Map is a table with one value READ COMMAND gets data from table offsets it digPntr and puts it in DigCtrl
Segments = display(DigCtrl)
Check_Finish:
IF _PARAM1 = No THEN ' CHECKS TO SEE IF OPTO-TRANSISTOR IS BLOCKED
ops = M_STOP ' MUST PUSH THE CLEAR BUTTON TO RESET
ENDIF
RETURNINT ' reset the RTCC value and re-enables interrupts
' UPDATE_DISPLAY: ' DECIMAL POINT DISPLAY
' IF DPDigit = 0 THEN
' READ DP_Map + ms, display(0)
' ELSE
' READ Seg_Map + ms, display(0)
' END IF
Start:
IF _PARAM1 > 0 THEN ' If Rb.0 is 1 then go else don't start
GO = _PARAM1 ' Go will equal one to stop timer
ELSE
GO = 0
ENDIF
' Clear and Start go directly to Ra.0 and Ra.1. Ra.1 going high starts the timer, but the timer must be in mode zero defined as RAO_CLEAR.
' The timer starts by updating ops to M-Run. The timer stops when the opto-transistor goes high causing the comparator to go high the timer
' will be stop by changing the ops mode to M_STOP
MAIN:
DO while steps < 61
GOTO UPDATE_DISPLAY
IF Go = Yes THEN
IF ops = RA1_START THEN 'ops sets the three mode of operation 0) stopped and cleared 1)running
ops = M_RUN ' 2) stopped
ENDIF
ENDIF
IF GO = No THEN
IF ops = M_STOP THEN
PUT @ms, 0, 0, 0, 0, 0
ops = RA0_CLEAR
ENDIF
ENDIF
LOOP
UPDATE_DISPLAY: ' called only once
READ Seg_Map + ms, display(0) ' display (0) is the LED for milliseconds
READ Seg_Map + hs, display(1) ' Transfers seg_Map data table into display array.
READ Seg_Map + ts, display(2) '
READ DP_Map + sec01, display(3)
IF sec01 = 0 THEN
display(4) = %11111111 ' Blanks ms display
ELSE
READ Seg_Map + sec01, display(4)
ENDIF
steps = steps + 1
RETURN
Seg_Map: ' segments maps
' .gfedcba
DATA %00111111 ' 0
DATA %00000110 ' 1
DATA %01011011 ' 2
DATA %01001111 ' 3
DATA %01100110 ' 4
DATA %01101101 ' 5
DATA %01111101 ' 6
DATA %00000111 ' 7
DATA %01111111 ' 8
DATA %01100111 ' 9
DATA %01110111 ' A
DATA %01111100 ' B
DATA %00111001 ' C
DATA %01011110 ' D
DATA %01111001 ' E
DATA %01110001 ' F
DP_Map:
DATA %11110111
All of this:
has to be after the RETURNINT
In fact the TRIS_B, PLP_A, and COMPARE won't even run because they are before the "Start:" label. The line "PROGRAM START" tells the SX chip where to start executing code from. Anything before the "Start:" label will never be executed.
I have moved the code around, so this should at least compile:
Bean
Post Edited (Bean (Hitt Consulting)) : 10/23/2007 1:32:47 PM GMT
