SX sounds great, can I ....
Hi,
Many years ago I had a Basic Stamp which I had a lot of success with. However, for the last year or so I have been playing with AVR's and with a lot of help from many people have made some great projects. My current project is a Head Tracker for VR and I have 3 accelerometers, 3 gyros and 2 magnetometers with an 8 channel 16 bit ADC and an Atmega16. I am also using an HD44780 compatible LCD to aid the development. I am only just now integrating the data from all the devices and I have a lot of numbers to crunch. I am thinking that the AVR will not be fast enough for what I want, hence my search for a faster chip.
I have spent the last few hours reading about the SX and they sound great, but I am wondering how simple it will be for me to move to the SX chip. What I need is serial communications @115200bps using a Max232, SPI interface to the ADS8344 16bit ADC, an EEPROM to store calibration data and the LCD for use during development. Would this be a big task to set up? Any thoughts, advice or recommendations will be greatly appreciated.
Maybe, the "trickiest" part you will have to master is the banked structure of the RAM memory, and the paged structure of the program (EEPROM) memory. Not understanding these concepts can cause you a lot of trouble when your projects grow, and you need to make use of more memory.
As you had mentioned - you were successful with the AVRs due to a lot of help from many people. When you look at the SX section of this forum, you will recognize that there are many helping hands around, and that questions always find answers here.
Now it's up to you to decide whether you take the red pill, or...
Greetings from Germany,
G
http://www.parallax.com/dl/docs/prod/prop/PropellerDSv0.3.pdf
Bean
My goal is to live forever...Or die trying.
www.hittconsulting.com
