My Low Cost LED Power Supply
william chan
This circuit directly powers LEDs directly from 240v AC (110v should also be possible but half the current ) without transformers
and can supply up to 250mA to power 3 white 1watt LEDs in series without any need for ballast resistors.
This whole circuit can be embedded in a bulb form, to truly create a LED light bulb.
The circuit works, but it is not perfect.
Anybody can guess what's the weakness of this circuit?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
Is that what you are thinking?
- Sparks
D2 is just there to prevent C4 from exploding when there is no load.
In this circuit, current regulation is the theme, not so much on voltage regulation.
Hint: If the bulb is screwed on not so tightly, a lot of big sparks will play out like fireworks.
www.fd.com.my
www.mercedes.com.my
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
