Did anyone ever figure out the NO DISK error when running editor? — Parallax Forums
metron9metron9 Posts: 1,100
edited 2007-10-23 15:19 in General Discussion
I just re installed stamp software (newest version from downloads section)
Vista system I get error no·disk Press cancel or continue and get it a second time third time is a charm and it runs.
I rebooted the computer after install and now it is fixed.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 10/20/2007 10:05:51 PM GMT
    edited 2007-10-22 12:26
    Funny you should mention this.· The other day I started my Propeller Tool app and I got a "No disc in D drive error".· I thought this was incredible odd because I have never accessed my D (DVD) drive with the Propeller Tool.· I ignored the error and the Propeller Tool started just fine.· I haven't seen the error since.· Odd...
    Timothy D. Swieter
    tdswieter.com
    One little spark of imagination is all it takes for an idea to explode
    edited 2007-10-22 13:56
    Yes, I've had the issue since I've worked directly with my SD card from the editor..
    (And since removed the SD adapter, (drive letter) from this machine)
    Since it wasn't my primary computer, I've haven't really worried about it.
    Oldbit
    Buttons . . . check. Dials . . . check. Switches . . . check. Little colored lights . . . check.
    — Calvin, of 'Calvin and Hobbes.
  • Skywalker49Skywalker49 Posts: 172
    Metron .. look at this thread. You are not alone.
    http:http://forums.parallax.com/showthread.php?p=655541
    regards, Ed
