Boe-Bot. Beginner
Hello everyone,
I am thinking about picking up the Boe-bot full kit (USB). I was just wondering what all I will be able to do with just that kit. Also I found some interesting parts over at www.hobbyengineering.com that I would be interested in putting to use. I was just wondering if they are compatible and how to tell if i can put a part onto the boe-bot. Sorry if this is a basic question but I am just starting into robotics.
The BoeBot is an excellent way to begin in robotics. If you scan these forums, you'll find all sorts of projects that people have developed and learned by doing. The BoeBot is an excellent platform to learn about robot navigation, particularly with the addition of a PING sensor to the IR sensor that comes with the full kit.
The best part about Parallax, is that so much is available for free... the software you use to write your programs is free as is the documentation for everything they sell. The best way to get an idea of what you can do with the BOEbot is to review the documentation which you can download here... http://www.parallax.com/dl/docs/books/edu/Roboticsv2_2.pdf
You will need to be a bit more specific as to which items you were looking at at Hobby Engineering... technically, you can hook up any electronic device to a Stamp, though some may need some type of "interface circuit". A good example is a toy DC motor... you can connect it to a Stamp, but you need to use a motor controller circuit between them as the power draw of the motor is more than the power that the Stamp can source.
One item im looking at is something like:
http://www.hobbyengineering.com/H1743.html
Thanks for your answers.
If you are interested, I have a Boe-Bot with serial input (you can buy the USB to Serial adapter from Parallax) and all the manuals and parts. I have worked through the book and examples and will be moving up to the Penguin.
I also have the Boe-Bot Tank Tracks, Boe-Bot Crawler kit, Ping & servo, the compass chip, and a 5 function Keychain transmitter & receiver set that could be used to remote control the Boe-Bot.
I could let all this go for a great price which would save you alot. I could ship this via USPS Priority for about $10 and you can pay me via PayPal.
If you are interested, email me at roy-kathycarlson@msn.com
You can seel the list of items. cost and offer price at the robot forum under Roy Carlson.
Sorry about the early price mistake since my cost for all the items is well over $400
Post Edited (Roy Carlson) : 10/24/2007 12:15:31 AM GMT
There really no way to tell, because it will ultimately be up to you, the robot builder, to figure out. If you can figure out a way to hook something up and run it, then it works with the Boe-Bot!
What's a Microcontroller?
IR Remote·for the BoeBot
These can be found under the Downloads menu item in the webpage on Stamps in Class tutorials on the main Parallax webpage.
The only Parallax chips that wouldn't work are any 40-pin modules, or the Propeller or SX28 or SX48 families. I understand there IS a Propeller 24-pin module in the works, though.
I had used it as a BoeBot controller before the Propeller Protoboard came out. Worked fine with IR, compass, servos, wireless (xBee).
--DFaust
We do have lots of add-ons that can be used with the Boe-Bot too, you can see some video and sample code on the links at the Stamps in Class Mini-Projects sticky-thread at the top of the Stamps in Class forum.
-Stephanie Lindsay
Editor, Parallax Inc.
