BS2, SEROUT, and iPod. Help Needed!
I'm trying to use the BS2 to remotely control my ipod via serial communication. I have a dock connector and all the wiring worked out, but the code is giving me issues. I found the ipod's communication protocol here: http://ipodlinux.org/Apple_Accessory_Protocol#iPod_Remote_.28Mode_2.29 but I still can't figure out what my SEROUT command needs to look like. I just want to be able to pause, play, skip forward, skip backward, and change the volume. Can anyone help me figure this out?
If I read the documentation correctly, the serial communication is a standard 8N1 protocol and the Baud needs to be at least 19.2k.· You should also be using TTL levels to communicate with.
Beau Schwabe
IC Layout Engineer
Checksum VAR Byte
Length VAR Byte
Mode VAR Byte
Command1 VAR Byte
Command2 VAR Byte
Main:
Length = $03
Mode = $00
Command1 = $01
Command2 = $02
GOSUB Serial1
Length = $03
Mode = $02
Command1 = $00
Command2 = $02
GOSUB Serial1
Length = $03
Mode = $02
Command1 = $00
Command2 = $00
GOSUB Serial1
PAUSE 1000
GOTO Main
Serial1:
Checksum = $100 - ((Length+Mode+Command1+Command2)+$ff)
DEBUG "Checksum = ", HEX Checksum, " "
SEROUT 1, 16416, [noparse][[/noparse]$ff,$55,HEX Length,HEX Mode,HEX Command1,HEX Command2,HEX Checksum]
RETURN
From what I understand, this should switch the ipod to remote control mode and turn up the volume every second, but I get no response at all when I run it. I've tried to do some research on the 8n1 standard, but I feel like I'm still missing something there. As for TTL levels, I have no idea what that is. I've also tried using "32" for the baudmode instead of "16416", going by the calculations in the BS2 documentation, but that didn't work either.
Try this for the SEROUT line...
SEROUT 1, 16416, [noparse][[/noparse]$ff,$55,Length,Mode,Command1,Command2,Checksum]··· '.... Inverted
SEROUT 1, 32, [noparse][[/noparse]$ff,$55,Length,Mode,Command1,Command2,Checksum]··· '.... Non-Inverted
.... If you’re driving it from a STAMP, then the output is TTL (0V to 5V)· If you are driving it from your PC which you should not be doing without a proper voltage level shifter, the voltages can swing from -12V to 12V
Beau Schwabe
IC Layout Engineer
