Free Pins on Proto Board
I was just counting the free pins on the Proto board (assuming I'm using VGA, mouse, and keyboard) and got 20, with 12 in use.·
But, one thing I don't understand is the markings on the schematic (http://www.parallax.com/dl/docs/prod/prop/Propeller-ProtoBoard-v1.1.pdf) for pins P24-P27.· They seem to indicate that these pins might be normally used for something, but I don't see what...
Anybody know?· I see they are hidden behind the crystal.· Maybe this is all they mean?· But, why the different symbols on each one?
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Graham
You'll still need an MOSFET or small switching junction transistor to drive the relay. Neither the Propeller nor the PCA9554 have enough current drive for most relays. There is one reed relay from US Relays that I found in the Digikey catalog that will work directly off a Propeller I/O pin. It's rated for a 3V input and the current required is about 20ma. Their stock number is Z622-ND and the manufacturer's number is R1A3AHH. All you need is a diode reverse connected across the coil (like a 1N4001).
I just checked and I need 40 mA to drive the relay...· Still, if I bussed·a few·outputs together, it might work...
Post Edited (Rayman) : 10/19/2007 9:43:19 PM GMT
Can sink 500 mA with OC output that can handle up to 50 V. I already have a PCF8574, which looks a lot like the PCA9554...
You can use 74ls06 to drive 40mA relay
Sapieha
Thanks for mentioning the PCA9554. I think that will be a nice one to have in my back pocket if I ever paint myself into a corner and need extra pins. A colleague of mine would have found this one useful on his project because he ran out of pins. He ended up doing something different, but the software ended up being somewhat ugly.
Seems like once you are done, you see a better way of doing it. That's one of the hard realities of being an engineer.
The more I know, the more I know I don't know.· Is this what they call Wisdom?
Post Edited (Ken Peterson) : 10/20/2007 3:18:11 AM GMT
MDC3105
It's only in single and dual packages and only in SOT23 package. But, I think it will make things much simpler for me...
But, on second thought, I need to drive at least 4, and maybe 10 or more relays. So, I think I'll level shift the I2C bus to 5 V with a PCA9512 and then use a PCF8574 (or PCA9554) with ULN2803 to control up to 500 mA relays.
Graham
p.p.s [noparse];)[/noparse]
