Using VB to control USB PSC
I saw a reference in the forum to sample VB code to control the PSC. The post stated that it was in completed projects, but I acnnot find it. Can anyone point me in the right direction. I have the PSC running fine on the PC using Visual Servo Controller from Brookshire Software, but I also need to send some additional commands to it through my VB application. I do have the example BS2 code that is in the PDF, but can use any sample VB code that I can get.
Thanks!!!
Thanks!!!
http://forums.parallax.com/showthread.php?p=671804
If you are a little familiar with VB Express this will walk you through building a generic interface. Since I posted the examples I have given it a little more thought and made a few modifications·to·the template that give it added flexibility.
If the original template works for you private message me and I will help you fine tune it for your application.
Jeff T.
