a thread that started as a noob-ish asm question — Parallax Forums
Lee MarshallLee Marshall Posts: 106
edited 2007-10-21 23:30 in Propeller 1
im having problems with my vga driver:
vgastart                        'code to output blank lines
                        rdlong bitmap_base,par          'store base address of bitmap
                        mov dira,IOdir                       'these two lines of code are not working
                        mov outa,#$ff
                        mov vcfg,videoconfig            'configure video generator
                        mov vscl,videoscale
                        mov frqa,frequencya             'set up counter module to produce internal 64 mhz signal, and start counter
                        mov ctra,countera
                        mov currentline,vlines
loop6                   call #blankline
                        jmp #loop6
IOdir         long      %00000000_11111111_0000000000000001
the spin code to start the routine:
PUB Main
  cognew(@vgastart,@bitmapbase)
this is the simplest of problems, i cant get a pin to change from 0 to 1.
all i am hoping to accomplish with the above code, is set pin 0 of port a to logic 1
however, this code does nothing to pin 0, it just remains at 0.
i first noticed this when i tried to output the counter(mode 2) on pin 0.
in spin, the pin works fine, so i havent killed the pin or anything.
why isnt pin 0 doing anything??
I hear and I forget. I see and I remember. I do and I understand
-Confucius
Post Edited (Mr Crowley) : 10/19/2007 10:48:43 PM GMT
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2007-10-19 15:19
    Perhaps removing the mov ctra,countera may help, if you happened to set the counter up on pin zero it may override it.
    Graham
  • Lee MarshallLee Marshall Posts: 106
    edited 2007-10-19 15:39
    ok, ive commented out(') the ctra and frqa lines, but still nothing.
    i can even comment out everything else, so they are the only two instructions in the program, and still nothing
    -Confucius
    Post Edited (Mr Crowley) : 10/19/2007 3:45:16 PM GMT
    edited 2007-10-19 15:46
    You are definitely looking at P0 not just the first pin on the prop?
    the function blank line just jumps back?
    All the res at the end?
    Voltmeter set to volts?
    Tried spin code to check hardware?
    Graham
    Have you configured the video generator to use pin 0?
    Part of the difficulty in giving you help is that we don't have all the information. You've shown a code fragment, but left off important constants.
    What you've shown should work, so the problem must be in the parts you haven't shown.
    edited 2007-10-19 15:59
    P0 is the first pin of the dil40 prop
    no, it has a load of waitvid commands
    yes
    im using a scope, so yes, i tested it with the clock signal, to check setup is correct.
    yes, it works.
    here are the all constants im using(well, they arent all used as constants):
    bitmap_base   res       1                       'pointer to bitmap(1536 longs(6KBytes))
    temp          res       1
    videoconfig   long      %0_01_0_0_0_000_00000000000_010_0_11111111
    videoscale    long      %000000000000_00000001_000000100000
    countera      long      %0_00010_100_00000000_000000_000_000000
    frequencya    long      $8_000_0000
    currentpixel  long      0
    currentline   long      0
    tilecount     long      0
    linecount     long      0
    hfp           long      24                      'horizontal details in pixels
    hsync         long      136
    hbp           long      160
    hvid          long      1024
    vfp           long      3                       'vertical details in lines
    vsync         long      6
    vbp           long      29
    zero          long      0
    vlines        long      768
    vsync_colors  long      %00000000_00000010      'color 0 : hsync 1, vsync 0     color 1 : hsync 0, vsync 0
    hsync_colors  long      %00000001_00000011      'color 0 : hsync 1, vsync 1     color 1 : hsync 0, vsync 1
    vid_colors    long      %11111111_00000011      'color 0 : syncs 1, rgb 000     color 1 : syncs 1, rgb 111
    '                       hsync:
    '                       requires:
    '                       hsync_pixels1 (x1)
    '                       hsync_pixels2 (x4)
    '                       hsync_pixels3 (x5)
    hsync_pixels1 long      %11111111_000000000000000000000000                      'front porch, then beginning of sync pulse
    hsync_pixels2 long      %11111111111111111111111111111111                       'rest of sync pulse
    hsync_pixels3 long      %00000000000000000000000000000000                       'back porch
    the video generator is configured to use pins 16:23, 2 color, vga mode.
    as i said, i commented all the lines which werent related to outputting 1 on pin 0
    i should have given the constants before, sorry bout that.
    the program now looks like this:
    vgastart
                            mov dira,IOdir
                            mov outa,#$ff
                            'mov vcfg,videoconfig            'configure video generator
                            'mov vscl,videoscale
                            'mov frqa,frequencya             'set up counter module to produce internal 64 mhz signal, and start counter
                            'mov ctra,countera
    loop6                   'call #blankline
                            jmp #loop6
    -Confucius
    edited 2007-10-19 16:23
    It may just be the way you have copied and pasted but you do have two res at the top there
    Is there an org?
    Graham
  • BaggersBaggers Posts: 3,019
    edited 2007-10-19 16:26
    is vgastart before or after the data?
    that would be an issue
    edited 2007-10-19 16:39
    vgastart is before, the data is right at the end.
    there is an org just before the vgastart(missed that in the copypaste)
    Graham Stabler said...
    is there something wrong with doing that, i thought it just reserved a certain amount of longs.
    EDIT: ok, it works now if i change res statements to long ones...so, what are res statements meant to be for?
    bitmap_base   long       0                       'pointer to bitmap(1536 longs(6KBytes))
    temp          long       0
    -Confucius
    Post Edited (Mr Crowley) : 10/19/2007 4:48:20 PM GMT
  • Ken PetersonKen Peterson Posts: 806
    edited 2007-10-19 16:59
    All of your res statements should be at the end, shouldn't they?
    The more I know, the more I know I don't know.· Is this what they call Wisdom?
    edited 2007-10-19 17:51
    ah, i see, i thought the res did the same as the long statement.
    now, im confused again, why is the counter producing a frequency of around 7.1 mhz.
    here is my setup:
    input clock to propeller: 4.0mhz
    system clock pll at 16x(producing 64mhz sys clock)
    freq register containing: $8000 0000(hex)
    plldiv 010(/32)
    APIN: 00000(pin 0)
    clkmode: PLL single ended
    the way i worked it out:
    64mhz(system clock)
    /2(counter value halves frequency) = 32mhz
    *16(internal pll as described in appnote) = 512mhz
    /32(plldiv) = 16mhz
    however, there is clearly a gap of 0.14us between each peak _/''''''\___/''''''\__ on pin 0
    1/0.00000014 = 7142857
    7.142857MHz?
    it should be 16.0000000MHz!
    i have to assume this is related to my misunderstanding of the way the plls for each counter work
    -Confucius
  • deSilvadeSilva Posts: 2,967
    edited 2007-10-19 18:08
    No, your understanding of the working of the counters is quite correct - however you overdid it..
    The Datasheet says: "For stable operation, it is recommended that the VCO frequency be kept within 64 MHz to 128 MHz."
    512MHz is definitely not possible...
    edited 2007-10-19 18:30
    thanks desilva, is working now.
    -Confucius
    edited 2007-10-19 19:39
    Sorry I should have better explained what I meant about all the res being at the end of the dat section, it's in the tricks and traps section and it trapped me!!! It does just reserve the memory it's just it needs to come after all longs etc for some reason.
    edited 2007-10-19 21:35
    my code so far(im aiming for 60hz 1024x768):
    'VGA Driver by Lee Marshall
    CON
      _clkmode = XINPUT + PLL16X
      _xinfreq = 4_000_000
    VAR
      long bitmapbase[noparse][[/noparse]1536]
      byte cog
    PUB Main
    PUB Running : YesNo
      YesNo := cog
    PUB Stop
      cogstop(cog~ -1)
    DAT
            org
    'Driver Start
    vgastart
                            mov dira,IOdir
                            mov vscl,videoscale
                            mov ctra,countera
    loop7                   mov currentline,vlines          'set currentline to 768
    loop6                   call #whiteline                 'do a white line
                            djnz currentline,#loop6         'do this 768 times
                            call #vertical_sync             'do vertical sync
                            jmp #loop7                      'start again
    whiteline                                               'produce a white line
                            mov tilecount,#32
    loop8                   waitvid vid_colors,vid_test     '32 horizontal pixelgroups of 32 pixels(1024 pixels)
                            djnz tilecount,#loop8
                            waitvid hsync_colors,hsync_pixels1                      'hsync
                            waitvid hsync_colors,hsync_pixels2
                            waitvid hsync_colors,hsync_pixels3
    whiteline_ret           ret
    blankline                                               'produce a blank line
                            mov tilecount,#32
    loop1                   waitvid vid_colors,zero         '32 horizontal pixelgroups of 32 pixels(1024 pixels)
                            djnz tilecount,#loop1
    blankline_ret           ret
    vsync_line
                            mov tilecount,#32
    loop2                   waitvid vsync_colors,zero
                            djnz tilecount,#loop2
                            waitvid vsync_colors,hsync_pixels1                      'hsync
                            waitvid vsync_colors,hsync_pixels2
                            waitvid vsync_colors,hsync_pixels3
    vsync_line_ret          ret
    vertical_sync                                           'perform vsync
                            mov linecount,vfp               'front porch lines
    loop3                   call #blankline
                            djnz linecount,#loop3
                            mov linecount,vsync             'sync lines
    loop4                   call #vsync_line
                            djnz linecount,#loop4
                            mov linecount,vbp               'back porch lines
    loop5                   call #blankline
                            djnz linecount,#loop5
    vertical_sync_ret       ret
    temp          long       0
    IOdir         long      %00000000_11111111_0000000000000000
    countera      long      %0_00001_110_00000000_000000_000_000000
    frequencya    long      $2_000_0000
    currentpixel  long      0
    currentline   long      0
    tilecount     long      0
    linecount     long      0
    hsync         long      136
    hbp           long      160
    hvid          long      1024
    vsync         long      6
    vbp           long      29
    zero          long      0
    vlines        long      768
    vsync_colors  long      %01010100_00000010      'color 0 : hsync 1, vsync 0     color 1 : hsync 0, vsync 0
    hsync_colors  long      %00000001_01010111      'color 0 : hsync 1, vsync 1     color 1 : hsync 0, vsync 1
    vid_colors    long      %11111111_01010111      'color 0 : syncs 1, rgb 000     color 1 : syncs 1, rgb 111
    '                       hsync:
    '                       requires:
    vid_test      long      %11111111111111111111111111111111
    fit
    this program is meant to produce a completely white screen.
    however, it doesnt work:
    the monitor just flicks on, and off as if it cant lock onto the frequency, this could be due to the fact i am running a 64mhz pixelclock and it is meant to be 65(the link says the values arent critical)
    web.mit.edu/6.111/www/s2004/NEWKIT/vga.shtml
    or it could be the following:
    it appears that when the back porch of the VSYNC(not hsync) finishes, the vsync line dips down for a moment.
    this could be what is throwing my monitor off.
    in the pics, the top trace is one of the color lines, the bottom trace is the VSYNC line.
    the first pic is of the vsync pulse, notice the composite sync embedded in the color line inverting during the vsync, no problems there.
    the second pic features a small dot in the bottom right hand quadrant, this is the weird VSYNC pulse that shouldnt be there at the end of the vsync back porch.
    the third pic is a magnified view of the second.
    ive been looking through the code for the last hour, and still cant find the reason for this pulse, the only time the vsync should be at 0v is when the vsync_colors is being used.
    i am grateful to anyone who can find the source of this anomaly.
    my wiring of the vga is identical to that of the protoboard
    edit: added link
    -Confucius
    Post Edited (Mr Crowley) : 10/19/2007 11:46:07 PM GMT
    2304 x 1728 - 958K
    2304 x 1728 - 956K
    2304 x 1728 - 956K
    edited 2007-10-19 22:28
    No longer noobish enough for me to help [noparse]:)[/noparse]
    edited 2007-10-20 17:36
    I have changed the counter settings, so that it approximates 65mhz as close as possible(this is difficult with a 64mhz base clock), however, the monitor still isnt working, so it must be what i mentioned earlier(the vsync anomaly).
    i am currently having the program run loops of vsync:
    loop7
                      call #vertical_sync
                            jmp #loop7
    the little blip is still appearing right at the end of the back porch lines of each vsync.
    this means it is definitely something in the vertical_sync routine. specifically, at the end.
    i am at a loss, i cant see how this is happening..
    -Confucius
    Post Edited (Mr Crowley) : 10/20/2007 5:43:59 PM GMT
    edited 2007-10-20 18:01
    You coul try commenting out various parts of vertical_sync to find out exactly where it occurs or insert your own little blip to locate this one exactly in the code.
    edited 2007-10-20 21:18
    ah-ha!
    i think i have the answer.
    and graham, thank you for the suggestion, it helped realise the following:
    im running the pixel clock at the same frequency as the system clock.
    this means i have 32 clocks free between waitvid commands. i have a feeling that at this point, i have used up all my available clock cycles with jmps/rets and djnzs,
    so, the video gen had finished shifting out pixels, meanwhile the program hasnt got to the next waitvid, forcing the video outputs low for a time(the blip) until the waitvid is reached.
    i discovered this by decreasing the pixel clock from 64mhz to 32 mhz. this made no blip at all.
    could this be it??
    -Confucius
    Post Edited (Mr Crowley) : 10/20/2007 9:31:38 PM GMT
    edited 2007-10-20 23:28
    I don't think one COG is fast enough to drive this display scheme. Chip posted some VGA high-resolution drivers a while back.
    Here is the thread: http://forums.parallax.com/forums/default.aspx?f=25&m=154758
    Graphics, in tile mode, take two COGs. A third can draw an overlay cursor. The overlay is done electrically, with the third COG, just outputting it's data to the display pins, timed just right to position the cursor.
    The one I linked is 1020x768, and was written on an 80Hmz clock.
    edited 2007-10-20 23:51
    woohoo, it works! ive got it to display a test pattern of blue/white stripes, all i gotta do now is make it work with a bitmap. smilewinkgrin.gifsmilewinkgrin.gifsmilewinkgrin.gifsmilewinkgrin.gif
    -Confucius
    edited 2007-10-21 00:21
    Nice!!
    edited 2007-10-21 00:42
    Alright, woot!! and I helped without understanding a thing [noparse]:)[/noparse]
  • Fred HawkinsFred Hawkins Posts: 997
    we have proof
    712 x 566 - 8K
