IR LED and Reciever
                    I am trying to make a optical switch (larger gap than I've been able to find off the shelf) and thought the IR Transmitter Kit with the IR·reciever would work well.· Does anyone know if you have to have it tuned to a frequency to change the On/Off signal or can it be set to "seeing light or not seeing light"?· Also is there a response speed limitation·to the reciever meaning·is there a limit to how many cycles between on/off could I get per second?
Thanks, Palmer421
                            Thanks, Palmer421
If you want a simple on/off response, use a phototransistor.
The documnetation I looked at last night said that you can detect different ranges to calculate distance from an object by bouncing the IR light off something which could be cool for other projects.·
I only saw·a photoresistor and a IR transistor available, were you talking about one of those?· I was worried that·something like that·wouldn't respond/reset fast enough.·
Thanks again, Palmer421
2. IR-Transistor -- basically a transistor, whose 'base' input is provided by IR light. Response is very fast. Easily confused by sunlight.
3. IR-Decoder -- A sophisticated 3-terminal device. It's 'looking' for an IR light, 'blinking' at a 38 Khz rate. This is called "a 38 Khz modulated IR signal". If it does not see the IR light 'blinking' at 36 to 42 Khz, it completely ignores it. This behavior is excellent for filtering out ambient light.
It's #3 that Parallax uses in their "IR" circuits. These devices were created to recieve TV (and other) IR Remote signals. As such they're pretty cheap, and very reliable. When they 'see' the 38 Khz modulated IR light, they output a TTL 'low' on their signal pin -- when they don't 'see' the signal, they output a TTL 'high' (though some need a 10 Kohm 'pull-up' resistor).
They're also pretty fast, able to faithfully recieve 1.2 mSec and 600 uSec 'bursts' of IR light. Note at 38 Khz, 600 uSec is about 23 'blinks' of the 'sending' signal. I'm not sure exactly how few 'blinks' it takes to activate the decoder.
Basically I'm trying to make my own Flash Tracer / Silencer for an MP5 Airsoft gun (ex: http://www.mfiap.com/airsoft/acce/tracer.htm). I can't seem to find them anywhere anymore. So the optoswitch will trigger some UV or really bright visible light LEDs to charge some glow in the dark BBs for a tracer round effect. Any thoughts?
Parallax does sell a phototransistor (www.parallax.com/detail.asp?product_id=350-00018). I don't think I have a datasheet for this anymore and there's not a link on the webstore page, but e-mail Parallax support and I'm sure they'd send you one.
There are some bright UV LEDs available for charging phosphorescent stuff. The main problem is that they're potentially dangerous since you can't see the light from them and they can damage your eyes. Experiment with bright blue or bright white LEDs and see how well they do at it. The LED would be very close to the BB, so most of the beam would be directed to the BB.
