X-ray tolerant chips?
While I'm releatively sure these Stamp Chips et. al. get X-rayed all the time in our security conscious nation.·Has there been any problem that X-rays have caused?
--Paul
--Paul
In any event, the problem is that lots and lots of x-rays can, over years, speed up the loss of charge and you may lose bits in the EEPROM eventually. This is much like the issue with photographic film. Unprocessed photographic film will start to fog after a lot of security x-rays. High sensitivity film will fog faster much like high density flash EEPROM, with its smaller cells and less charge, will also react faster. Poorly maintained security x-ray machines may have higher x-ray exposures than well maintained ones.
I wouldn't worry too much about it. Your computer has these chips in it. Your cell phone has these chips in it. Unless you travel for a living ... and travel a lot ... it's not much of an issue.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Thank you both for the information. I was fairly certain that they were X-ray tolerant. The EEPROM would make sense to·be more sensitive. I remember erasing·eproms with a UV light back in the "COCO" days.
Paul
