eb500 and j2me midlet
Im trying to send a string to the eb500 via a midlet , fist the program searches for available devices and prints on screen details about them, after that it tries to make a connection to a device with service 0x1101which is the one used for the eb500, it is supossed to show the string on the debuger window on the eb500 but nothing happens. Can any1 help me on this pls? am I missing something?
the code I am trying to use is the following :
for he midlet
try{
DiscoveryAgent myDiscoveryAgent = LocalDevice.getLocalDevice().getDiscoveryAgent();
add = LocalDevice.getLocalDevice().getBluetoothAddress();
myDiscoveryAgent.startInquiry(DiscoveryAgent.GIAC,this);
try {
Thread.sleep(10000);
} catch (InterruptedException ex) {
ex.printStackTrace();
myDiscoveryAgent.cancelInquiry(this);
RemoteDevice [noparse]/noparse remoteDevices = myDiscoveryAgent.retrieveDevices(DiscoveryListener.INQUIRY_COMPLETED);
DataOutputStream dos = null;
UUID myService = new UUID(0x1101);
servicios = servicios + myDiscoveryAgent.selectService(myService,ServiceRecord.NOAUTHENTICATE_NOENCRYPT,false);
try{
StreamConnection conn = (StreamConnection) Connector.open(servicios);
if (servicios != null) {
dos = conn.openDataOutputStream();
dos.writeUTF("Hola Oscar");
// dos.writeChars("Hola");
dos.flush();
dos.close();
} catch (Exception ex) {
for (int i = 0 ;i<remoteDevices.length;i++)
try {
results = results + remoteDevices.toString() + " " + remoteDevices.getFriendlyName(true);
} catch (IOException ex) {
} catch (BluetoothStateException ex) {
and the code for the eb500
' {$STAMP BS2px}
serialin VAR Byte
INPUT 5
PAUSE 1000
SEROUT 1,84, [noparse][[/noparse]"con 00:1A[noparse]:D[/noparse]C:8B[noparse]:D[/noparse]E:78",CR]
SERIN 0,84,[noparse][[/noparse]WAIT("ACK",CR)]
WaitForConnection:
IF IN5 = 0 THEN WaitForConnection
main:
serialIn(0) = 0
SERIN 0,84,1000,main,[noparse][[/noparse]STR serialIn\3\"!"]
PAUSE 100
LOOKDOWN serialIn(0),[noparse][[/noparse]100,101],serialIn
BRANCH serialIn,[noparse][[/noparse]test1, test2]
SEROUT 1,84,[noparse][[/noparse]"none", CR]
PAUSE 5
GOTO main
test1:
SEROUT 1,84,[noparse][[/noparse]"a"]
GOTO main
test2:
SEROUT 1,84,[noparse][[/noparse]"b"]
DEBUG STR serialIn,CR
GOTO main
for he midlet
try{
try {
try{
dos.flush();
dos.close();
try {
' {$STAMP BS2px}
serialin VAR Byte
INPUT 5
PAUSE 1000
WaitForConnection:
main:
serialIn(0) = 0
PAUSE 100
PAUSE 5
GOTO main
test1:
GOTO main
test2:
GOTO main
- Stephen
