Rechargeable 9v Lithium-Polymer batteries
Someone has finally made a rechargeable 9v battery that is as good or better than alkalines. I have a number of 9v driven devices (my voltmeter, my guitar fuzzbox, etc) and I hate putting in throw away batteries. Apparently, these Li-Poly batteries have a very low self discharge rate, so they're good for devices that sit around a lot, and they have as much or more capacity as alkalines. The batteries aren't cheap at $15, but they will get used many, many times. Also, the charger can charge both Li-Poly as well as NIMH and NiCD.
toolmonger.com/2007/10/13/a-more-powerful-long-lasting-rechargeable-9v-lithium-polymer/
PeterM
PeterM
Batteryspace has a 9v Li-polymer with similar specs at $8 each. If those can be recharged conservatively 100 times, then that is 8 cents per use and only one battery to recycle.
Tracy Allen
www.emesystems.com
48.0 mm x 25.0 mm x 15.0 mm. reg 9 volt battery
49.2 mm x 26.8 mm x 17.8 mm. Li-polys 9 volt battery
This battery may not fit in very many 9 volt battery box compartments
