UPDATED: Need some help with alittle servo not working/jitter!
Hello everbody. I need some help with some servo jitter. I have two servos hooked up to a basicSX OEM board(the servos work fine when i run a routine that isn't computer based) and I'm getting two words of data from a serial line at 9600 baud from a VB program i built myself(yay me). Anyway. The problem is, one of the servo's jitter. I did alittle debuging and it seems that which ever servo i address first in the code to pulsout jitters. The other does not(I switched up the servos just to maintain a control). Any helpful ideas as to remedy my problem?
Here's my code:
Post Edited (DiablodeMorte) : 10/11/2007 3:43:10 AM GMT
Here's my code:
' PULSIN.bs2
' {$STAMP BS2sx}
' {$PBASIC 2.5}
'Pin Declarations
Pulse PIN 0 ' pulse input pin
'Variables
pwmInput1 VAR Word ''PWM Input Variable
pwmInput2 VAR Word
'Constants
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
Scale CON $200 ' 2.0 us per unit
#CASE BS2SX, BS2P
Scale CON $0CC ' 0.8 us per unit
#CASE BS2PX
Scale CON $0CF ' 0.81 us per unit
#ENDSELECT
#SELECT $STAMP
T1200 CON 813
T2400 CON 396
T9600 CON 84
T19K2 CON 32
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T9600 CON 240
T19K2 CON 110
T38K4 CON 45
#CASE BS2PX
T1200 CON 3313
T2400 CON 1646
T9600 CON 396
T19K2 CON 188
T38K4 CON 84
#ENDSELECT
Inverted CON $4000
Open CON $8000
Baud CON T9600 + Inverted
pwmInput1 = 1830
pwmInput2 = 1830
goPwm:
'Attempt to handle more than one servo:
PULSOUT 6, pwmInput1
PULSOUT 5, pwmInput2
GOTO Main
'Main Program
Main:
DO
noData = 0
'PULSIN Pulse, 1, pwmInput ' measure positive pulse
SERIN 16, Baud, 20, goPwm, [noparse][[/noparse]DEC4 pwmInput1, DEC4 pwmInput2] ' receive one byte
GOTO goPwm
LOOP
Try shortening the timeout and speeding up the PC end of the control loop. Additionally, you could shorten the number of characters needed by sending 16 bits as two 8-bit characters for each value. That would halve the number of characters needed.
'Main·Program
Main:
··DO
····noData·=·0
····'PULSIN·Pulse,·1,·pwmInput·'·measure·positive·pulse
····SERIN·16,·Baud,·20,time_out,·[noparse][[/noparse]WAIT("PWM"),DEC4·pwmInput1,·DEC4·pwmInput2]·'·receive·one·byte
··· time_out:
····GOSUB·goPwm
··LOOP
goPwm:
·····'Attempt·to·handle·more·than·one·servo:
·····PULSOUT·6,·pwmInput1
·····PULSOUT·5,·pwmInput2
RETURN
Adjust your VB code to send like this.........SerialPort.WriteLine("PWM" & vbCR & pwminput1 & vbCR & pwminput2)
If you still get a little jitter try a slower baud.
Jeff T.
Sadly, I have a new interesting problem:
The servo's work now w/o much jitter(the wait command helped, i hit my head on the table when i read your post unsoundcode, I already knew the wait comand but i forgot!) but the new problem is this:
When all three servos are running now every so often they just stop working at all. I have to put my joystick back in the center position and then after about 4 seconds they start to work again. If i try to move too much on the joustick the servo's stop responding again. Any help?
Here's an updated code snippit.
goPwm: 'Attempt to handle more than one servo: PULSOUT 6, pwmInput1*100 'PAUSE 5 PULSOUT 5, pwmInput2*100 PULSOUT 7, pwmInput3*100 GOTO Main 'Main Program Main: DO SERIN 16, Baud, 50, goPwm, [noparse][[/noparse]WAIT("PWM"),DEC2 pwmInput1, DEC2 pwmInput2, DEC2 pwmInput3] ' receive one byte noData = 1 GOTO goPwm LOOPand the VB code i'm using:
Can you hook up an LED to a spare pin (don't forget the current limiting resistors) to use to tell where the Stamp hangs up ... turn it on just before the SERIN and turn it off just after goPWM so it's on during the SERIN.
Alter your VB code like this
MSComm1.Output·=·"PWM"·&·vbCr·&·Str(CurrentJoyR)· &·vbCr & Str(CurrentJoyZ)·&·vbCr & Str(CurrentJoyX) & vbCr
the carriage return will tell the Stamp to read into the next field.
Jeff T.
Jeff T.
