Servo32_Demo Object questions
I've been playing around with this program and trying to figure this out.
Below is a portion of the·object that·I dont know how to accomplish what I need it to do.·
'Pan selected DEMO servo3 & 4 back-n-forth opposite of each other
···· repeat temp from 1000 to 2000
····· waitcnt (cnt+125_000)
····· SERVO.Set(PanServo3,temp)
····· SERVO.Set(PanServo4,3000-temp)
···· repeat temp from 2000 to 1000
How·can this be·modified·to control two servos with different temp values.
For example I need servo 3 to travel from 1500 to 2000 and servo 4 to travel from 1000 to 1500.
I can do it where each moves but I cant get them to move at the same time.·
Is this even possible.
Paul
Paul
Try this....
Servos move in same direction:
repeat temp from 1500 to 2000 waitcnt (cnt+125_000) SERVO.Set(PanServo3,temp) SERVO.Set(PanServo4,temp-500) repeat temp from 2000 to 1500 waitcnt (cnt+125_000) SERVO.Set(PanServo3,temp) SERVO.Set(PanServo4,temp-500)Servos move in opposite·direction:
repeat temp from 1500 to 2000 waitcnt (cnt+125_000) SERVO.Set(PanServo3,temp) SERVO.Set(PanServo4,3000-temp) repeat temp from 2000 to 1500 waitcnt (cnt+125_000) SERVO.Set(PanServo3,temp) SERVO.Set(PanServo4,3000-temp)▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
I understand your two examples.· My example that I gave was actually a bad one.
What I meant is something like this
Servo1 needs to move from 1200 to 1500
Servo2 needs to move from 1000 to 1800
This is more of what I was trying to ask in the first post.
Subtracting or adding to temp dosent quite work.· Unless I'm missing something.
is there another way of coding the repeat so multipule values can be instereted only directed to
either one of the servos.
Hope this makes sense
Paul
Post Edited (Paul K.) : 10/10/2007 6:42:23 PM GMT
This is just math trivia... What you need to do is determine a common reference denominator that
represents the passage of time from point A to point B.· This can be any arbitrary value.· Typically,
I use 0 to 100 as a percentage, but because we want a decent resolution we might use something
more like 0 to 1000.· So we setup the subroutine like this....
repeat temp from 0 to 1000 waitcnt (cnt+125_000) 'This is simply an arbitrary delay, you can adjust this to whatever you want temp1 = temp * 300 / 1000 'This equates to the current incremental temp value times the delta of Servo3 'so that while temp goes from 0 to 1000, temp1 will go from 0 to 300 ' '1500 - 1200 = 300 temp2 = temp * 800 / 1000 'Same thing for Servo4... This equates to the current incremental temp value 'times the delta of Servo4 so that while temp goes from 0 to 1000, temp2 will 'go from 0 to 800 ' '1800 - 1000 = 800 'Servo3 '--------------------------------------------------------------------------------- SERVO.Set(PanServo3,1200 + temp1) '<--- Don't use BOTH ; use one or the other 'or to switch direction... SERVO.Set(PanServo3,1500 - temp1) '<--- Don't use BOTH ; use one or the other '--------------------------------------------------------------------------------- 'Servo4 '--------------------------------------------------------------------------------- SERVO.Set(PanServo4,1000 + temp2) '<--- Don't use BOTH ; use one or the other 'or to switch direction... SERVO.Set(PanServo4,1800 - temp2) '<--- Don't use BOTH ; use one or the other '---------------------------------------------------------------------------------·
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/11/2007 1:54:38 PM GMT
Stan Dobrowski
