following boe-bot problem
hello guys,i was trying this following boe-bot from boe-bot book from page 282 for later to be used in my pan and tilt project to detect my hand.
however right now i dont know if this is working well--it really did detect my hand or book,however i dont think it is that accurate---is there anyway i can make the sensors more accurate in reacting to its obstacle in front and why is my boe-bot backing up when she detects nothing-always---why is this so?
here is the codes that i used[noparse]:([/noparse]exactly like in the boe-bot book page 282).
DEBUG "Program Running!"
[noparse][[/noparse] Constants ]
Kpl CON -35
Kpr CON 35
SetPoint CON 2
CenterPulse CON 750
[noparse][[/noparse] Variables ]
freqSelect VAR Nib
irFrequency VAR Word
irDetectLeft VAR Bit
irDetectRight VAR Bit
distanceLeft VAR Nib
distanceRight VAR Nib
pulseLeft VAR Word
pulseRight VAR Word
[noparse][[/noparse] Initialization ]
FREQOUT 4, 2000, 3000
[noparse][[/noparse] Main Routine ]
DO
GOSUB Get_Ir_Distances
pulseLeft = SetPoint - distanceLeft * Kpl + CenterPulse
pulseRight = SetPoint - distanceRight * Kpr + CenterPulse
GOSUB Send_Pulse
LOOP
[noparse][[/noparse] Subroutine - Get IR Distances ]
Get_Ir_Distances:
distanceLeft = 0
distanceRight = 0
FOR freqSelect = 0 TO 4
LOOKUP freqSelect,[noparse][[/noparse]37500,38250,39500,40500,41500], irFrequency
FREQOUT 8,1,irFrequency
irDetectLeft = IN9
distanceLeft = distanceLeft + irDetectLeft
FREQOUT 1,1,irFrequency
irDetectRight = IN0
distanceRight = distanceRight + irDetectRight
NEXT
RETURN
[noparse][[/noparse] Subroutine – Get Pulse ]
Send_Pulse:
PULSOUT 14,pulseLeft
PULSOUT 15,pulseRight
PAUSE 5
RETURN
is there anyway i can modify these codes to make it more sensitive and react better?
thank you in advance
Kpl CON -35
Kpr CON 35
SetPoint CON 2
CenterPulse CON 750
freqSelect VAR Nib
pulseLeft VAR Word
pulseRight VAR Word
DO
GOSUB Send_Pulse
LOOP
Get_Ir_Distances:
distanceLeft = 0
distanceRight = 0
irDetectLeft = IN9
irDetectRight = IN0
NEXT
RETURN
Send_Pulse:
PAUSE 5
RETURN
Andy Lindsay also has some additional material regarding IR detection and better PID control for things like IR following:
IR detection: http://forums.parallax.com/showthread.php?p=561496
Basic PID control: http://forums.parallax.com/showthread.php?p=529609
Excellent Boe-bot Dual PID discussion: http://forums.parallax.com/showthread.php?p=649354
