Organizing cables?
This forum is for topics related to the use of Parallax products. Parallax sells cables, so here goes...
Over the years,I have accumulated a ton of different cables. I have USB, Firewire, parallel, serial, video, Ethernet, RCA, 1/8" mini, 1/4" guitar, MIDI, etc, etc, etc. Does anyone out there have a good system for organizing and managing cables? It seems that about 80% of the cables are black, making them all look like each other.
Is there a good system of boxes? Hooks? Ties? I'm tired of having a heap of cables that gets all tangled, causing me to spend time un-tangling just to find out I don't have the cable I thought I did.
PeterM
PeterM
|__|___| etc
The ends would be open for cables to hang out.
Or you could have a board with all the holes drilled in it and place pegs in the holes to drape the wires/cables over.
Jeff T.
I·guess it depends on how many cables you need to store and how long they are.
Hope this helped!
But will try to set up something like what D Faust suggests soon.
(It's on the todo list, somewhere...)
Don't visit my new website...
This system works quite well for me.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
PeterM
i did however tear through my collection of cables and now it has its own gravitational pull.. once enough wires are added it becomes its own container, although it dosnt make it easy to unravl. i have a tote about 3x4 ft and 3ft deep packed with wires. but those are the ones i dont use often. i really dont think theres any really good way to hold them without making somehting to keep them seperated. i also tryed ziplock bags, but i sometimes cant find a bag to fit some cables into, like laptop power supplies and things with bigger boxes on them, i keep those in a night stand with my more importiant cables which i keep organised. so to summerise what im saying; keep the importiant cables organised, and the ones you rarely use, keep them out of sight so they dont get tangled with the importiant ones. its not a perfect solution but it helps a little.
