Graphics driver problem
is there some docs for the graphics driver. need to display a clock in a location of my display. using VGA 1280x1024 Tile Driver v0.9· need to display the clock in a 12x4 tile area. cant get it to work.
con
· bitmap_base = $5000
· gr.start
· gr.setup(8, 8, 0, 0, bitmap_base)
PRI largetxt | i,j
··· repeat i from 0 to 7
···· repeat j from 0 to 12
····· array.word[noparse][[/noparse]cols * (22 + i) + j + 32] :=· 22 << 10 + bitmap_base >> 6 + i + j << 3
··· gr.clear
··· gr.textmode(9,9,5,5)
··· gr.colorwidth(3,5)
··· gr.text (80,65,string("8:44"))
not for sure what i am doing wrong but i only see 8:4
con
· gr.start
PRI largetxt | i,j
··· gr.clear
your gr.start needs to be in a method.
so you need something like "Pub driver"
I am just starting to use the graphics driver myself, so I am not an expert yet. The Hyrda book provides great reference as well as reading through the forums. In the graphics_demo I see that the strings are defined in the DAT section. The strings must be zero terminated, I think I read that in the graphics program. I have implemented the driver with the text in the DAT section and gotten it to work. Be sure that your screen size is setup up right.
Move the x (80) and y (65) coordinates around some to be sure the item is not being clipped. I think the point specified is the center of the string display, not the left hand. I need to experiment more, but I think this is what I was experiencing yesterday.
Timothy D. Swieter
tdswieter.com
One little spark of imagination is all it takes for an idea to explode
Using (9,9,5,5) means: an extreme enlargement! Justification is Center/Center.
So it seems you have run out of the 128x128 pixel frame you initialized the driver with...
So eg set all to 12. As you do not use double buffering you should have ample space, even for 12x 16... you should avoid distortion on a 3:4 display...
But what I do not understanding is why you use those settings 9,9,5,5 for textmode in the first place...
It even took me 10 minutes to reconstruct your program from your puzzles to verify my opinion.
' 1 April 2007
' This program demonstrates 1280x1024 VGA, NSTC, and the mouse
' simultaneously on the Propeller Demo Board. This code is a
' mess. It was thrown together to make a visual demonstration
' for the Embedded Sytems Conference in April 2007.
CON
· _clkmode = xtal1 + pll16x
· _xinfreq = 5_000_000
· cols = 80
· rows = 64
· tiles = cols * rows
· spacetile = $220
· display_base = $6000
· w_x = 19
· w_y = 10···············
OBJ
· vga···· : "VGA_1280x1024_Tile_Driver_With_Cursor"
· gr····· : "graphics"
VAR
· long· col, row, color
· long· array[noparse][[/noparse]tiles/2]
· long· cursor_x, cursor_y, cursor_col, cursor_def
PUB start | i, j, k
· 'start vga tile driver
· vga.start(16, @array, @vgacolors, @cursor_x, 0, 0)
· 'start and setup graphics
· gr.start
· gr.setup(8, 8, 64, 64, display_base)
· 'fill screen with text
· print($100)
· 'make some graphics tiles on the screen
··· make_graphics_tiles(w_x, w_y, 21)
··· 'do some graphics
··· gr.clear
··· gr.colorwidth(2,0)
··· gr.textmode(9,7,6,5)
··· gr.colorwidth(3,4)
··· gr.text (60,0,string("8:44"))······
PRI make_graphics_tiles(x, y, c) | i, j
····· array.word[noparse][[/noparse]cols * (y + i) + j + x] :=· c << 10 + display_base >> 6 + i + j << 3
PRI print(c) | i, k
'' Print a character
''······ $0D = new line
''· $10..$FF = character
''····· $100 = clear screen
''····· $101 = home
''····· $108 = backspace
''$110..$11F = select color
· case c
··· $100:·············· 'clear screen?
····· wordfill(@array, spacetile, tiles)
····· col := row := 0
··· $110..$11F:············ 'select color?
····· color := c & $F
dat
vgacolors long
· long $3C043C04······ 'lt grey on dk grey
· long $3C3C0404
· long $44A844A8······ 'magenta
· long $4444A8A8
· long $88A888A8······ 'magenta light
· long $8888A8A8
· long $E400E400······ 'dk yellow
· long $E4E40000
· long $9C009C00······ 'red
· long $9C9C0000
· long $FF80FF80······ 'red/white
· long $FFFF8080
· long $FF20FF20······ 'green/white
· long $FFFF2020
· long $FF28FF28······ 'cyan/white
· long $FFFF2828
· long $C0408080······ 'redbox
· long $3010F020······ 'greenbox
· long $3C142828······ 'cyanbox
· long $FC54A8A8······ 'greybox
· long $A8540000······ 'dark grey box
· long $C030F050······ 'graphics colors
· long $88143000
· long $8008FC54
sorry for some misunderstandings. But as the comment says: This is a total mess: A tiny graphics plane tuned into a specific place with lots of literal constants all around... Little chance for you. So please change this:
gr.setup(14, 8, 64, 64, display_base) ' 14 rather than 8 .... gr.textmode(9,9,6,5) ' 9 rather than 7 ... repeat j from 0 to 14 ' 14 rather than 12I could give you further explanation what this all means, if needed
Have fun!
The more I know, the more I know I don't know.· Is this what they call Wisdom?
http://www.rayslogic.com/propeller/Programming/RaysStuff.htm
PS:· I really recommend the 1024x768 driver for practical apps...
I can as well try some explanations....
(1) What does GRAPHICS.SPIN do? It fills a memory buffer organized as a rectangular view in units of 16 LONGS, imagined to be stacked vertically. Lets call them MEMORY CHUNKS. They contain 16 pixels, and a LONG contains two bits per pixel to allow for 4 different colours.
(2) Mike has used a very small buffer 128 x 128 pixels, 8x8 being the first two parameters of gr.setup(8,8,....)
GRAPHICS can paint on any of those pixels, so for a graphic operation those chunks are of no further relevance. The origin of the drawing co-ordinates will normally be "top left", but you can adjust that. Mike has "centered" his co-ordinate system
gr.setup(8, 8, 64, 64,..)
So drawing something to (0,0) would show it in the center!
(3) Drawing text is very flexible; text can be horizontally or vertically aligned. Text can also be enlarged!
gr.text(9, 9, 5...
would enlarge the normally 8x4 font to a 72x36 size. Now Mike was painting 4 characters, with intercharacter spacing of 5, which would take 4*36 + 3*9 = 171 pixel, somewhat more than the 128 available. This does no harm, as GRAPHICS is a very cleanly written program...
But what is this 3*9 stuff?? Well the "spacing" is not counted between the characters, but absolutely, including their nominal width (which is 4). And it is measured in "un-enlarged" units...
I here again add the description oftextmode, as very often the alignments parameters are forgotten
(4) Now how does this 128x128 "graphics window" correspond to the things the real video driver (TV or VGA) outputs? Well, using tiles of course. We just put the addresses of our MEMORY CHUNKS into the tile_matrix (generally called "screen") of the driver.
The conventions are as hunderedfold explained here in threads: 6 bits color, 10 bits TILENUMBER; TILE NUMBER is something when multiplied with 64 gives the byteaddress.
So this is where we need a pair of nested loops
repeat i from 0 to 7 repeat j from 0 to 12 array.word[noparse][[/noparse]cols * (22 + i) + j + 32] := 22 << 10 + bitmap_base >> 6 + i + j << 3so the tiles of eight columns times thirteen lines were directed to the MEMORY CHUNKS of the GRAPHICS driver.
Well, didn't we only have a 8 x 8 tiles memory for the graphics.
(a) That's true - but what is memory? You see that "bibmap_base" has dangoriously been set to $6000. So there is memory 8k bytes at least. And the structure of the memory, is determined by this harmlessly looking << 3.
Exactly! <<3 absolutely determines that you have got 8 rows (of 16 pixels) the length of those rows being arbitrary, but clipped by the settings in the setup parameter..
A lot to change when you change.....
Keep a stiff upper lip for it
Post Edited (deSilva) : 10/10/2007 3:30:10 AM GMT
(1) First you posted some code out of context. However the most likely problem was obvious and explained to you.
(2) You did not react to those explanations other than saying that it does not work.
(3) Then - 24 hours later - you posted a different piece of code - which differed not only considerably but in relevant aspects from your first posting. No wonder you couldn't be helped...
(4) I undertook the trouble to fix your bugs.. there was a specific reason for it, though it is considerably after midnight local time now.
(5) Then you posted something of your own findings; which generally is fine, as you have of course to work on it!
So this all does not look like team work to me....
Post Edited (deSilva) : 10/10/2007 5:00:00 AM GMT
Right now the program that i am using is run 7 out of 8 proc's
3 for the vga driver
1 for the main program
1 for the full dupex serial
1 for the graphics driver
1 for a procss that changes the color table to cause flashing text.
mike goettling
Some remarks, some allredy made.
- If you not absolutely have to do something else, use the "simpler" driver Rayman keeps advertising.
- Updating the color tables is a simple job that can be included into the VGA driver during vertical sync, if need be
- As you have experienced, a most annoying fact is missing documentation. So why not write a "How to use GRAPHICs with different video drivers!" for us? I already mae a start with my posting four above
Post Edited (deSilva) : 10/10/2007 1:51:57 PM GMT
