Bug, feature or am I missing something
evening all,
Not to jump on the current trend of IDE bashing, but either this is a wierd one, or more likely I am missing something.
I am starting·a cog with an Assembler routine.· Currently all it does is keep updatin a variable in hub (shared) ram.· My Cog start code is:
The (significant part of the) cog code is:
Simple?
No.· That doesn't work.· The "asmSamplerData" value stays at 75 - as initialized in the SPIN.
If I change the order of the variable declarations to put
at the bottom of the list.· It works and the "asmSamplerData" goes to 100.
Bizarly I have another bit of code in the same app that works with the byte varname[noparse][[/noparse]100] at the top and it works fine.· This issue also works if you change it to "long asmSamplerData[noparse][[/noparse]100]"
using IDE 1.05.5
Appologies if this has been seen and is a "gotcha" already - did look quickly.
If nothing else (aka not a bug) a "gotcha" or a compiler warning would be·useful.
Thanks all,
James
Post Edited (Javalin) : 10/4/2007 7:01:07 PM GMT
... byte asmSamplerData[noparse][[/noparse]100] long s, ms, us byte myCogID byte SPI_CLK, SPI_CS, SPI_DO, SPI_DI byte index word adcMUX long adcData[noparse][[/noparse]13] long stack0[noparse][[/noparse]30] long running long currentSample long tempSample ... pub Start asmSamplerData := 75 myCogID := cognew(@samplerEntry,@asmSamplerData)
DAT org samplerEntry mov t1_ptr,par ' SPIASM Block mov adcChValue,#100 wrbyte adcChValue,t1_ptr
Simple?
using IDE 1.05.5
Thanks all,
James
Try writing:
aligned long
In the line just before "byte asmSamplerData[noparse][[/noparse]100] "
Seems to be the culprit.
James
I guess the other code is in memory later, as its a bigger lump of memory - hence why it works
Been going arround this one for about 2 hours!
James
There are good internal reasons for this (see Propeler Manual, and many discussions here, deSilva Tutorial, etc., etc.)
The sequence of VAR allocation is changed by the compiler:
LONG first, then WORDs , last BYTEs
So having an odd number of words declared will bring you into trouble.
Putting your byte array to the end had an effect, as now exactly 6 byte variables were allocated before the array, just compensating for the odd numbr of words.
Be careful! SPIN is no fun
The more I know, the more I know I don't know.· Is this what they call Wisdom?
See my instructive posting about "The four different kinds of @"
As the tricky re-sorting of variables makes it unnecessary for the compiler to know anything about their alignment, I doubt that this information is easy to obtain..
Edit: I have to correct myself. The last phase of the compiler MUST know the relative adress of any variable, this could be checked for long alignment - however this last phase will most likely have no idea of the context in which this adress is used...
Post Edited (deSilva) : 10/4/2007 8:12:58 PM GMT
I disagree. Since it's possible, by a simple visual inspection of each object, and without reference to any other loaded objects, to determine a VAR variable's alignment (an operation you so rightly performed above, BTW), there's no reason that alignment data can't be known at compile time, even though the actual addresses are not. It's inconceivable that all the instances of every object's variables get thrown into one huge blend-o-matic, allowing one instance's bytes to become separated from its longs by another instance's words, for example.
On the other hand: The second parameter of COGNEW ist just ... a value. So it can be (and is) computed in a general way.
As the compiler is doing no "constant optimisation", @var will be postponed to execution time as well as any more complex construction. Ex:
So I guess a valid work arround would be to have the:
cognew(@entry,@alongvariable)
and in the "alongvariable" pointing to an array of bytes?
Seems a shame to have to use a 512 array of longs to hold 512 bytes.
Spose otherwise you'd have 128 longs and break it up that way?
Cheers,
James
Chip Gracey
For all those complications I do not recommend using PAR , but using any simple DAT variable... Examples can be found in deSilva's Tutorial and in some discusions here and there...
E.g.:
long·byte asmSamplerData[noparse][[/noparse]100]
The manual suggests this should work.· I'm pretty sure I've used something similar myself...
But what you can of course do is put IT ALL into the DAT section:
Post Edited (deSilva) : 10/5/2007 6:07:57 PM GMT
When you look at the syntax it's all in VAR.
I gave the rules for re-ordering again in the sixth posting above.
Another option would be a way to alias one variable to another:
Granted, the notation BYTE[noparse][[/noparse]@lbuf][noparse][[/noparse]index] covers the latter situation adequately, but any enhancements for improving code readability are always welcome.
